Author Topic: Trying to interface Interact Gas Pedals with Arcade  (Read 859 times)
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« on: October 08, 2004, 02:31:15 pm »
I have an outrun cabinet that has the "origjnal" gas and brake pedals.    I'm putting a dreamcast in the cab for racing games.  I want to interface the pedals that came with the DC steering wheel.
The DC pedals insides look like this:
The arcade pedals insides look like this:
I've got the wires where they are supposed to be, gas works fine, brake even kind of works, but the brake light on 4x4 evo is always on.  When I DO hit the brake, it does stop and then go into reverse, which is what it does when I use the DC pedals.
I'm guessing that the Pots have different values or something?  maybe move the brake pot a little?  Anyone know what to do to make it work?
Thanks in advance.
Art
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
JackTucky
Re:Trying to interface Interact Gas Pedals with Arcade
« Reply #1 on: October 08, 2004, 04:00:05 pm »
Hey, take the gears off of the pot, then move the pot so it doesn't brake, then put the gear back on.
Done.
JackTucky
« Reply #2 on: October 08, 2004, 10:49:10 pm »
I've got it setup so the pots start at zero, but i can't press the gas enough now.  Should I replace the pots from the DC controller into the arcade one, or what?  Thanks
pcates
  • Last login:January 05, 2011, 08:15:57 pm
« Reply #3 on: October 10, 2004, 12:16:15 am »
I would try to switch them out. I think the arcade ones are 5K, and the DC may be 100, so there would be a big difference. If they dont fit they may have some at radio shack. Good luck...
P.S. Did you stuff that 21" monitor in yet??
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: October 10, 2004, 08:09:42 pm »
Can't you just recalibrate in windows?
Robin
Knowledge is Power
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
« Reply #5 on: October 11, 2004, 04:44:50 am »
If I remember properly, the Dreamcast doesn't use windows! 8)
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #6 on: October 12, 2004, 12:07:49 am »
D'oh! I was somewhere else when I wrote that. :-[
AKAIK (and it's not that much):
a) dreamcast calibrates the center on bootup
b) IIRC, each pedal should output a range of ~2.5 volts (2.3v should be enough); I think one does ~ 0.2-2.5, the other ~ 2.5-4.8.  I don't know the supplied current, but V = I * R.  "The rest is left as an exerise for the student."
A couple things to note: since it's calibrated at bootup, the center volts can be other than 2.5, but the ends still need to be ~0.2v and ~4.8v.  Also, I'm basing this off a couple different gamepads; the dreamcast pedals might be different (but I doubt it).
Robin
Knowledge is Power
