Author Topic: VirtuaNES with MAMEWAH doesn't work anymore? YES it does.  (Read 4906 times)
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
« on: October 07, 2004, 01:40:41 am »
I tried a couple NES emulators and have decided on VirtuaNES.  I just can't get it to work with MAMEWAH.  I'm using VirtualNES 0.92e from www.screenshotarchive.com and MAMEWAH 1.51
I found settings for previous MAMEWAH versions at http://webpages.charter.net/rbecker5/emulators.html that should work.
Show DOS Box = 0
Send ROM Path = True
Use Long Filenames = True
Send ROM Extension = True
I started with a copy on my mame.ini and saved it as virtuanes.ini  with the following changes:
emulator_executable                       C:\Games\Arcade\NES\virtuanes092e\VirtuaNES.exe
send_rom_path                             1
send_rom_extension                        1
quotes_around_romnames                    0
long_filenames                            1
show_dos_box                              0
When MAMEWAH tries to fire the game through VirtuaNES, I get a VirtuaNES error saying "don't open a "rom_xx" -verify roms file".  Most of the time this is a double error.  If I open the game with just VirtuaNES, close it, and then try with MAMEWAH, I can get it to a single error (and the game loaded) only if I show dos box.
Needless to say, I'm baffled.  Is there a remnant from the copied mame.ini calling for VituaNES to verify the ROM?  Maybe the new version of MAMEWAH changed something?
[edit]
I just noticed the log file for MAMEWAH:
10/7/04 12:38:12 AM C:\GAMES\ARCADE\NES\VIRTUA~1\VIRTUA~1.EXE C:\Games\Arcade\NES\10-YARD FIGHT (U).nes
10/7/04 12:38:14 AM Error 75 Path/File access error in EMU_VerifyROMs
It doesn't help me, but maybe someone else can make sense of it?  If I just open the roms directly with VirtuaNES, they play great.
« Last Edit: October 07, 2004, 11:19:42 am by Crazy Cooter »
Re:VirtuaNES with MAMEWAH doesn't work anymore?
« Reply #1 on: October 07, 2004, 05:43:33 am »
show_dos_box                              0
This should be set to 'no'.  As MAMEWAH doesn't recognise '0' for this setting, it is defaulting to 'auto', which will not work for any other emulator than MAME.
Crazy Cooter
« Reply #2 on: October 07, 2004, 11:18:57 am »
Booyah!
Thanks Minwah.
I switched show_dos_box to "no" and enabled "switch to full screen on ROM load."
It was all my mistake, in the \mamewah\docs\ini.txt help file it lists the options for the show_dos_box as "no / yes / auto."  I just didn't catch it. :-[
