Author Topic: FS: Coin doors, cabinets, controls  (Read 1015 times)
Raven..
  • Last login:June 29, 2021, 12:51:50 am
« on: October 02, 2004, 12:26:39 pm »
I have a couple of coindoors to sell here.  One Bally-Midway attached to an empty Solar Fox cabinet (no monitor, bezel, marquee, partial wiring, intact power block, CP intact sans flightsitck).  Coindoor looks ok, cabinet has been poorly painted over green but should clean up.
The other is on an empty, full-size Turbo cabinet (painted over blue).  Coindoor looks good and is still wired up.   Controls and power block included with cabinet.
$50 for everything.
Monitor is gone for now.  I need it for testing a Narc I just got in, while I convert it to JAMMA.
I'll try to get some pics up this weekend, or you can come by if you're around DFW area.
« Last Edit: October 02, 2004, 10:24:12 pm by EyeDoc »
Raven..
Re:FS: Coin doors, cabinets, controls
« Reply #1 on: October 02, 2004, 10:25:59 pm »
Sorry, see revised post.  If I get the new monitor for this Narc, then I will pull the burned one back out of it.
« Last Edit: October 02, 2004, 10:48:45 pm by EyeDoc »
fixumdude
  • Last login:July 23, 2021, 10:02:08 pm
  • Getting Better at Arcade Controls
    • Arcade Controls
« Reply #2 on: October 06, 2004, 11:49:55 pm »
I'm interested (I hardly see anything in the DFW area).  Which side of the metroplex are you located on?
Raven..
« Reply #3 on: October 07, 2004, 02:21:49 pm »
I'm in Lewisville.  PM me if you want to come by and check them out.
