Author Topic: Character Animation in FE-3DARCADE :-)  (Read 3910 times)
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« on: September 10, 2002, 10:42:41 am »
I had to test it after I said in the thread below that it in principle should work...and it does :-)
Bones animation including those from charater studio in max will play automatically on models in the fe. Either as part of the environmental model...the best way... or even as a cab...in the movie below I mapped the model to I-robot in the gamelist overriding the irobot model...so instead of it the animated character is shown...
This should be cool to add all sorts of activity to the arcade...Working crane machines you name it  :)
video:
http://www.i-modernist.com/character.mpg
Peter
Lilwolf
Re:Character Animation in FE-3DARCADE :-)
« Reply #1 on: September 10, 2002, 04:56:14 pm »
the mpg seems corrupt.  downloaded it twice
)p(
« Reply #2 on: September 10, 2002, 05:04:10 pm »
strange runs ok here...
a copy is also here: http://3darcade.mameworld.net/character.mpg
you may have to copy that into the adress bar...mameworld does not like linking ;-)
Peter
  • Last login:Yesterday at 10:07:01 pm
« Reply #3 on: September 10, 2002, 08:51:48 pm »
I tried it too... wmp says it needs the llama codec or some such nonsense.  I beleive it's the video compression you used that's screwing it up.
)p(
« Reply #4 on: September 11, 2002, 01:31:58 am »
ok another codec  ;)
Peter
)p(
« Reply #5 on: September 11, 2002, 05:55:03 pm »
As I uploaded the creature model anyway...you can also try it yourself in the fe:http://www.i-modernist.com/creature.w3d
put it your models folder and to let it show up as in the video adjust the irobot entry in arcades/lists/fpsdemo2.atf to:
|I, Robot|irobot|1983|Atari|||Shooter / Misc.|.36b10|Yes|mame|arcade|creature|etc.|etc.
Notice the creature entry after arcade...that will override the Irobot model showing up. Remove the model after you tried it from your models folder...
peter
