Author Topic: rotating arcadeOS  (Read 1315 times)
coldrain
  • Last login:October 29, 2004, 06:42:33 pm
  • INSERT COIN..!
rotating arcadeOS
« on: September 30, 2004, 11:29:33 am »
can anyone please tell me how to rotate the display in arcadeOS..? I have got my monitor in my cocktail cabinet but need to rotate the display.
Coldrain
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
Re:rotating arcadeOS
« Reply #1 on: September 30, 2004, 01:38:04 pm »
Don't know if this will help - it depends on how much work you've done. There is a great cocktail FE here:
http://www.mikebillings.com/postnuke/html/modules.php?op=modload&name=frontend&file=index
I have a friend that sells these in a Compaq (slots right into a cocktail with ease) already totally configured for
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #2 on: September 30, 2004, 01:50:10 pm »
Coldrain
I think you should be able to use the space bar?  You can also configure the rotation to a specific keys.  Try looking at the Doc file that comes with ArcadeOS,  I believe it should help you out.
« Last Edit: September 30, 2004, 01:51:34 pm by creatine28 »
coldrain
  • INSERT COIN..!
« Reply #3 on: September 30, 2004, 02:37:37 pm »
Thanks all,
Silly me, I forgot to tell MAME to rotate the screen as well as arcadeOS,
Note to self "there are two config files now"  ;)
I am 75% done on my cabinet, got the PC inside and running, just got to build the control panels now, got some pic's of the build and will set a website so anyone else whos building can hopefully get a few ideas.
Thanks for the link, I am interested in the compaq's for 95 quid, any more deatails..?
