Author Topic: mamewah and file folders  (Read 1653 times)
btoddkelley
  • Last login:October 20, 2013, 04:52:05 pm
« on: September 29, 2004, 10:03:46 pm »
Iam setting up mamewah with Sega CD and am a little unsure how to proceed. I have used mamewah with epsxe(playstation). I re-named all of the all of the files to .bin and generated a list. mamewah performed flawlessly.
     My sega CD collection is different. Each game is in a folder. The folder contains music tracks and an iso file. Launching the iso file from gens starts the game. How do I get mamewah to list the iso's from in the file folders?
Todd
For it is not enough to have a good mind, rather the main thing is to apply it well.
- Descartes
Re:mamewah and file folders
« Reply #1 on: September 30, 2004, 05:35:11 am »
You could try setting the rom_extension to nothing (leave blank), in an effort to list *. - this should work for listing the games, not sure about launching them...
How do you do it from a commandline?  gens c:\roms\gamename\gamename.iso ?
Can you do it with: gens c:\roms\gamename ?
btoddkelley
« Reply #2 on: September 30, 2004, 02:36:50 pm »
Yes, that is how I launch it.
I will try your suugestion when i get home.
Todd
- Descartes
btoddkelley
« Reply #3 on: September 30, 2004, 11:57:21 pm »
When I leave Rom  extention blank I get a runtime error 9.
Any thoughts?
And yes, you had the command line correct before.
Todd
- Descartes
« Reply #4 on: October 04, 2004, 05:57:55 am »
How about if you put a space there (not sure if this will work)?
Alternatively, I think you'll need to make a DAT file, and generate the list using that.  I think there is a DAT-creator program at Howards site - www.oscarcontrols.com/lazarus .
wj2k3
  • Last login:August 22, 2006, 12:23:48 am
  • Not!
« Reply #5 on: October 04, 2004, 09:46:55 am »
I use a * to list all the files in the my multi-emulator set-up for Mamewah.
It lists all my files and shortcuts, but not the folders.
You could create shortcuts (or any file with iso name) in the rom folder and then launch a bat file from Mamewah such as
SegaCD.bat  that includes:
      gens c:\roms\%1\%1.iso
Just make sure Memewah does not send rom path or extension.
If I had an ISO i would try this oput for you but it seems like it shoudl work.
-wj2k3
