Author Topic: Problem getting GensAVGA to work right  (Read 1317 times)
arcaic
  • Last login:October 05, 2007, 09:15:04 am
« on: September 28, 2004, 05:43:43 am »
Hi all,
I've just been setting up GensAVGA in my cab and cannot get it to launch properly.
I can get it to launch from Mamewah 1.51 it goes full screen but just shows a diagonal line pattern until I press escape when it then runs the game I selected. Once running all is fine.
I am running Windows XP Pro SP1 with Mamewah 1.51 and GensAVGA
This link is a 3mb video of whats going on. Sorry about the quality and ignore the odd colours as the green gun on my monitor is flipping out >:(.
You can see the diagonal line pattern. That stays there until I hit escape and then after a bit of flickering it runs ok!
Any idea's. I have searched but cant find a clue.
It will run fine if you issue the followiing from either a command prompt or the new task dialog.
d:\gens\gensavga.exe roms\Sonic the HedgeHog.smd
Cheers
Andy
Here is the contents of my ini file for gens.
### gens.ini ###
emulator_title                            GENS
### List Generation Settings ###
rom_path                                  d:\gens\roms
rom_extension                             smd
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       d:\gens\gensAVGA.exe
send_rom_path                             1
send_rom_extension                        1
quotes_around_romnames                    0
long_filenames                            1
show_dos_box                              auto
default_options
extra_options_1
extra_options_2
### Artwork Locations ###
artwork_1_image_path
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               0
saver_type                                launch_scr
scr_file                                  d:\arcaic\arcaicinvaders.scr
wrapper_executable
wrapper_options
movie_path
### Additional Settings ###
music_path
controls_dat_viewer_executable
controls_dat_viewer_options
auto_launch_controls_dat_viewer           0
ipc_file_or_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
Re:Problem getting GensAVGA to work right
« Reply #1 on: September 28, 2004, 10:14:02 am »
show_dos_box yes
NEVER use 'auto' except for MAME.
« Last Edit: September 28, 2004, 10:14:55 am by Minwah »
arcaic
« Reply #2 on: September 28, 2004, 10:55:26 am »
Thanks for the reply
I've tried setting Show_Dos_box to all of 0,1, Yes,No, True and false but every time I exit mamewah and look at the ini file again it is set to Auto. I'll check again tonight.
What should it be set to for Gens/GensAVGA?
You can see from the AVI that Gens is launched and runs full screen it just doesnt seem to receive the path/filename of the rom correctly for some reason.
Cheers
Andy
arcaic
« Reply #3 on: September 28, 2004, 11:48:01 am »
Thanks for the kick in the appropriate place.
I tried 'yes' not Yes or YES or True or 1 and it worked.
Idiot users  :-[
Cheers
Andy
« Reply #4 on: September 28, 2004, 01:24:57 pm »
Idiot users  :-[
Heh, as of v1.51, the 'yes' is not case-specific...forget about True / False, that's gone for good :)
