Author Topic: Vertical Windows  (Read 1684 times)
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
Vertical Windows
« on: September 28, 2004, 12:46:21 am »
At one point in time many moons ago I thought I ran across a method of modifying some version of windows for those that were running a vertical monitor setup so that windows itself was rotated 90 degrees
I thought it was something other than what is some times available with some video card settings.
I've searched for that without success this evening.
Anyone remember where I have seen this before or am I remembering something that doesn't exist?
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Vertical Windows
« Reply #1 on: September 28, 2004, 12:55:11 am »
  • Last login:Yesterday at 10:07:01 pm
Re:Vertical Windows
« Reply #2 on: September 28, 2004, 12:57:34 am »
Forget that low-performance software junk.  Do you have an ati radeon card or a newer geforce card?  You have hardware rotation then assuming you install the right drivers.  (Catalyst for ati, i'm not sure for nvidia cards).
Unlike pivot pro this will actually work well.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Re:Vertical Windows
« Reply #3 on: September 28, 2004, 07:26:32 am »
The ArcadeVGA (ATI radeon 7000) driver supports rotation by  +90, +180 and - 90 degrees.
I use the +180 because my monitor is upside down - it works like a dream!
daywane
  • GRRRR!
Re:Vertical Windows
« Reply #4 on: September 28, 2004, 09:26:26 am »
some thing every one takes for granted. to flip your screen with your video card (at least for mine) right click on the ati icon and a menu pops up to flip... I have had my card for some time before I found that I could do it  :-[
I had no problems with pivot pro. I do have over kill on memory maybe thats why or also the vertical games I play are the oldest games and are not CPU hogs
« Last Edit: September 28, 2004, 09:28:54 am by daywane »
Re:Vertical Windows
« Reply #5 on: September 28, 2004, 10:18:08 am »
I actually found PivotPro worked surprisingly well on one of my old (333mhz) systems.
Of course, hardware rotation is much preferred...
rchadd
  • Made in Cornwall
Re:Vertical Windows
« Reply #6 on: September 29, 2004, 12:23:32 pm »
help!
correction - i thought it did...until i rebooted and then it reverted back to no rotation  :'(
any ideas on how to make the setting stay selected?
maybe edit the registry?
Lilwolf
Re:Vertical Windows
« Reply #7 on: September 29, 2004, 12:51:00 pm »
I posted the registry entry needed to enable it ages ago.  Search and you should find it.  There is a chance that it changed in the latest ATI drivers with the new interface.  I don't rotate mine, so I didn't care.. .just when I found it (looking for other options) thought others might want it.
btw, its default enabled in XP and disabled in 98.  But works in both.
This is only to show the rotation tab itself.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Vertical Windows
« Reply #8 on: September 29, 2004, 02:08:08 pm »
The current arcadevga runs off a radeon 9200.
