Author Topic: integrated sound card work with mame?  (Read 1109 times)
big daddy
  • Last login:May 01, 2019, 12:16:13 pm
« on: September 27, 2004, 03:14:23 pm »
I have 2 options for PC
-  Integrated 5.1 Capable Sound w/ front audio ports (free)
-  Sound Blaster Audigy 2 ZS with front audio ports (extra $65)
I know mame can use sound blaster compatable sound cards.  My question is, would it have any problems running on the integrated sound card?  Or should I upgrade to the Sound Blaster Audigy 2 ZS?  Note this is an hp a710e if that helps.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re:integrated sound card work with mame?
« Reply #1 on: September 27, 2004, 03:25:42 pm »
If you are running under windows, either should work just fine.
Later,
dabone
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #2 on: September 27, 2004, 03:26:46 pm »
i have never had problems with integrated soundcards.  pretty much all sound cards nowadays conform to the soundblaster standard and are "soundblaster compatible."  on the other hand, you really dont need to even worry about it unless you are using DOS or somesuch and need to figure out the soundblaster settings..
Craig
  • Last login:September 29, 2014, 05:51:56 am
    • Creation on the Web
« Reply #3 on: September 27, 2004, 03:39:29 pm »
Some motherboard BIOSes have an option to set the prefs for the onboard sound so you can use it with DOS.
I love the life I lead. I wish I could afford it.
krick
  • Gotta have blue hair.
« Reply #4 on: September 27, 2004, 10:08:05 pm »
For win32 versions of mame, either should work fine.
Regardless of what sound option you go with, you need to be concerned with CPU utilization.  If you're running a low powered CPU to start out with, having a bad sound chip sucking up CPU cycles can really hurt.
In general, onboard sound uses more cpu cycles than PCI sound cards, but this is not always the case.
You might want to borrow some sound cards from your friends and benchmark them against the onboard sound to see if the framerates suffer.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
