Author Topic: Act Light Gun Setup w/mame .87  (Read 2408 times)
Jakedakat
  • Last login:August 18, 2005, 08:40:06 pm
« on: September 24, 2004, 12:06:28 pm »
Iwas wondering if someone could help me with setting up an Act Lag light gun w/mame .87? I can get it to work with mame32 but I am not sure what I have to change in the ctrlr.ini file. I don't wanna use mame32 since I  allready have my cabinet setup w/mamewah. So any help would be great, thanks.
Rob
clanggedin
  • Last login:July 02, 2012, 11:08:55 pm
  • O'DOYLE RULES!!!
Re:Act Light Gun Setup w/mame .87
« Reply #1 on: September 24, 2004, 01:01:02 pm »
Try analog+. You can run that in Mamewah
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
« Reply #2 on: September 24, 2004, 04:24:13 pm »
Just a thought, but you can use mame32 in MAMEWAH, I used to.  I have since gone to fastmame, but basically mame32 (or any mame32 derivative) will work exactly like command line mame when running through an fe.  The nice part is you can modify the settings of a game in mame32 (say the screen resolution, or lightgun enabled option), and it will save these settings (under your /ini directory) and automatically run them in your fe.
Oh, make sure your ini path is set in your mame32.ini file (inipath ini)
Option 2) Add "-lightgun_device lightgun" to your default options in MAMEWAH:
Default Options = -lightgun_device lightgun
in your MAMEWAH/FILES/EMU1.CFG (assuming emu1 is MAME)
This option will enable the lightgun for all games that have a lightgun listed as their controller.  (Or you could just use "-lightgun", but that enables it for all games, which may be undesirable for you)
Other useful lightgun related options:
-[no]offscreen_reload
-[no]dual_lightgun
Cheers  :D
...they only live twice!...
(>")>----MAME----<("<)
Jakedakat
« Reply #3 on: September 24, 2004, 09:20:33 pm »
Thanks for the tips. But the problem ended up being something else. I went to the cfg directory and deleted the cfg files for the games I was having problesm with. And next thing I know the games would let me configure and play them :) Very odd.
Rob
MrBond
« Reply #4 on: September 25, 2004, 12:32:53 pm »
Huh, probably a MAME update issue then.  Sometimes you must delete your old cfgs...
