Author Topic: I-PAC Troubleshooting  (Read 4126 times)
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« on: September 08, 2002, 07:17:19 am »
Well I got my shiney new I-PAC all hooked up. I seem to have a few problems with the buttons.
I'm not exactly sure where to start, it could be anything.
I'm using the ps/2 connection (i COULD use usb) and I've also wired up db-25 connectors to be able to disconnect the I-PAC from the control panel. I'm using the standard default key settings as well.
Player two fire buttons 5 and 6 don't work. Also player 2 joystick down works but it also brings up the mame menu?!
Does this sound familiar? I couldn't seem to get that ctrl-alt-p thingie to work. Which trouble shooting program should I download from Ultimarc?
If you build a frankenpanel, chances are I don't care for you as a person.
Bursar
  • Last login:September 14, 2005, 06:57:07 am
Re:I-PAC Troubleshooting
« Reply #1 on: September 08, 2002, 08:29:31 am »
Sounds like you have a short somewhere. Can you open Notepad and see what happens?
If there's a short you should get characters appearing in Notepad.
Brax
« Reply #2 on: September 08, 2002, 09:00:08 am »
notepad appears to be fine. All the keys that should show (numbers and letters) , do. All the proper ones too.
And the 3 keys that I'm having trouble with all use letters and they show fine. but i agree still seems like a short. is it possible theres a problem with the i-pac?
Bursar
« Reply #3 on: September 08, 2002, 09:45:00 am »
Have you checked that the buttons are correctly mapped in MAME? I found that some buttons in some games weren't mapped properly.
Brax
« Reply #4 on: September 08, 2002, 09:54:13 am »
worth a try, that may fix the fire buttons but the joystick menu thing still eludes me.
I'll let you know you it goes
Brax
« Reply #5 on: September 08, 2002, 10:08:21 am »
ok, i feel stupid. It was all Mame configuration!
It works PERFECT now!
Hmm, now I need a friend to come over and play the player 2 slot!!!!   ;D
I was super careful with all the connections so I could avoid problems like this. I just didn't understand what was wrong! I'm not real big on electronics so i figured for sure that was the weakest link! Thanks so much for the help Bursar!
Bursar
« Reply #6 on: September 08, 2002, 01:13:35 pm »
No problem. Like you I took my time with the wiring to make sure I got it right first time.
I was trying to play SF II, and buttons 5 and 6 didn't do anything. I checked all my wiring again, and finally looked in MAME and found they weren't mapped. D'oh!
Glad you got it sorted.
Brax
« Reply #7 on: September 08, 2002, 05:21:19 pm »
Thats EXACTLY what happened to me..... Glad it happened to you first!  ;)
