Author Topic: MameWah 1.5 before install  (Read 2121 times)
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
« on: September 21, 2004, 07:59:47 pm »
before install MameWah setup ,system files are not installing and an error accur while run setup.bat.
due to which Mamewah is unable to install.
i already use 0.97...
BLUE BIRDS FLY WITH BLUE BIRDS
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
Re:MameWah 1.5 before install
« Reply #1 on: September 21, 2004, 09:01:03 pm »
what version of windows?
« Reply #2 on: September 22, 2004, 05:32:48 am »
Looks like they are installing but PaintX.dll is not being registered...do you have regsvr32.exe on your PC (\windows\system32) ?
KHAN
« Reply #3 on: September 22, 2004, 06:22:40 pm »
I am currently using win98.
when i run "regsvr32.exe " a messege shows in a picture apear.I think that there must be something wrong with regsvr32.exe plz check if u can....
otherwise i will install a clean windows installation.
« Reply #4 on: September 22, 2004, 07:16:07 pm »
Run it again but like this:
regsvr32.exe paintx.dll
...see what it says...
KHAN
« Reply #5 on: September 22, 2004, 07:23:42 pm »
I have run it several times but :-
i also download these files two times..
i will install windows clean installation tommorow.
it must be regsvr32.exe error..
« Reply #6 on: September 23, 2004, 05:26:46 am »
I wouldn't reinstall Windows, it doesn't look like anything is wrong with regsvr32 to me.
Read my previous reply - what does it say when you do this?
KHAN
« Reply #7 on: September 23, 2004, 08:36:46 pm »
hey Minwah!
dll register server in paintx.dll is succeeded.
this problem is solved....thanks..
But now the MameWah setup is not installing,believe me i am not wasting ur time...but this was as before i thought that due to the paintx.dll register error...
i also download Mamewah 3 times..
Setup is not installing MameWah...
it was quite comfortable installed in the old version...
error show in picture....
« Reply #8 on: September 24, 2004, 06:28:03 am »
Do you now have MAMEWAH v1.51?  In case you didn't realise I uploaded this at the start of the week - try that one... http://mamewah.mameworld.net/downloads.html
KHAN
« Reply #9 on: September 27, 2004, 12:48:11 am »
DEAR SIR,
                     I follow your directions but there is no improvements to install MameWah1.51
The setup file always gives an error shown in the picture.
i have try many times.Can you explain me what is missing?
I think that download the setup file  by using windows98 is going to be currupt...May be i am wrong.
It was the same when I do with kymeara setup early.
You may upload the setup file in a zip,to avoid some download errors...
At last i again go to with windowsXP...
« Reply #10 on: September 27, 2004, 07:47:10 pm »
DEAR SIR,
I don't know what is happening...no-one else has had this problem ??
