Author Topic: Mame 0.87 is out!  (Read 1070 times)
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Mame 0.87 is out!
« on: September 21, 2004, 07:11:10 pm »
Here is the whatsnew.txt of 0.87:
0.87
General Improvements:
Small update to the Kaneko drivers [Sebastien Volpe]
   - correct dipswitches for bonkadv
   - galpanib protection moved to machine\kaneko16.c, and sandscrp uses it
   - merged read/write memory maps for the 3 galpanic sets
Support 16 Joystick buttons [Norix]
8-way input fix for some mappy.c games (grobda, motos, phozon)
These games were set to 4-way input in the previous update. [anonymous]
Various Improvements [Angelo Salese]
   vamphalf.c
   improvements to vamphalf making it almost playable* it actually
   is now playable thanks to further improvements from others (see
   below)
   yumefuda.c
   temporarly patched eeprom check,fixed the graphics bankswitching
   & added sound in Yumefuda.I don't have added controls yet so it
   isn't playable.
   acommand.c
   Preliminary driver for Alien Command.Doesn't work yet...
   gstriker.c
   Very preliminary MCU emulation for World Cup '94.Hangs in
   various places since I don't have worked on them yet...
Implements the LEDs in "copsnrob" [Stefan Jokisch]
Fixed res_net.h related crash in Strike Bowling [Jarek Burczynski]
Improvements to Paint and Puzzle, game is almost playable [Nicola Salmoria]
Taito F3 Improvements [Bryan McPhail]
   Recalhorn now up to a playable standard.  This game exposed some bugs in the
   way the sprite renderer handled the special command bits (ie, the sprite
   list jump command occurs _after_ the current sprite has been processed, not
   before, plus bankswitch & global positioning flags can be set on the same
   sprite - they aren't exclusive, all makes perfect sense from a hardware
   point of view).  These fixes really should be put into taito_f2 and hybrid
   f3 games as well, though I doubt it will make any visual difference.
   Command War is playable too, except for the fact a layer doesn't seem to
   disappear when in the fighting sequence, and it's offset by 8 pixels in the
   movement sequence.
Rohga driver Improvements [Bryan McPhail]
   Rohga - Despite massive amounts of time spent on writing trojan's to probe
   the protection this still isn't complete.  The game hangs at the end of
   level 5.  A quick look at decoprot.c should reveal just how nasty this game
   is...  Graphics emulation is complete but the priority register never seems
   to be written properly (protection?) so some things look wrong.
   Schmeiser Robo - Not working 100%.  The game puts graphics info through the
   protection chip so in this case the game looks wrong even though the
   gameplay is actually running correctly.  Uses a strange double buffer
   feature of the protection chip that the Deco games don't (seem to) use.
Truco Clemente driver [Ernesto Corvi]
   This is as good I could get it working...
   Problems:
   - Wrong Colors
   - Audio is not 100% yet, I think.
   The board is definitely a conversion of some other board. My guess is a
   Pacman-style board, since
   some of the addresses match (watchdog, etc). Maybe somebody more
   familiar with those type
   of boards can figure out if they used the same color proms (I tried the
   MsPacman ones, and didn't
   match).
SPI background Decryption improvements [Ville Linde]
Fixed mrtnt colours (verified to use pacman proms) [vernimark]
Hyperstone core fixes [Tomasz Slanina, Pierpaolo Prazzoli]
   Tomasz Slanina
   - Added "undefined" C flag to shift left instructions
   Pierpaolo Prazzoli
   - Added interrupts-block for delay instructions
   - Fixed get_emu_code_addr
   - Added LDW.S and STW.S instructions
   - Fixed floating point opcodes
New Clones supported or promoted from GAME_NOT_WORKING status:
Super Pang (Japan) [Nicola Salmoria]
   set was decrypted, game now working
New Games supported or promoted from GAME_NOT_WORKING status:
Wizz Quiz [Pierpaolo Prazzoli]
Miss Bingo [Brian Troha]
Recalhorn [Brian McPhail]
   may crash on hi-score screen
Command War [Brian McPhail]
   still some clipping / layer problems
Vamp 1/2 [Angelo Salese, Pierpaolo Prazzoli]
   first working hyperstone based game
Truco Clemente [Ernesto Corvi]
   some graphical problems (see notes above)
New Non-Working games / clones supported
Alien Command [Angelo Salese]
   parts of the hardware still unemulated
Schmeiser Robo [Bryan McPhail]
   protection issues
« Last Edit: September 21, 2004, 07:12:09 pm by JoyMonkey »
