Author Topic: Where can I find COIN SLOT SWITCHES????  (Read 1057 times)
koolmoecraig
    • My Intervention
« on: September 20, 2004, 03:12:42 am »
Hello,
I am trying to find a source for some switches for my coin slots. The switches I have now function fine normally, but when they are hooked to my ipac, they work but come up as a stuck input which prevents me from being able to use the ipac shift function.
Thanks,
Craig
Trillian
  • Last login:August 19, 2004, 11:17:54 am
  • I will take the ring, though I do not know the way
Trillian
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re:Where can I find COIN SLOT SWITCHES????
« Reply #3 on: September 20, 2004, 11:57:45 am »
Kool, you may have them wired up wrong.
There's a thread somewhere on this board about which pins to wire to, and which ones NOT to.
NO MORE!!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #4 on: September 20, 2004, 12:58:18 pm »
you wire them up just like any other button switch on your cabinet.  Ground is the bottom pin and one wire to NO.  The switch should be labelled.
