Author Topic: what frontend to use on vertical cabs  (Read 2231 times)
daywane
  • GRRRR!
« on: September 18, 2004, 05:57:23 pm »
I have been working on this since 7am this morning
almost 11 hrs. I give .
what is a simple frontend to use with a vertical pc monitor.
I just thought Pivot pro would flip Mamewah. :'(
I have downloaded vertiwah but I have no idea on getting it to run.
I do not know how to use the command line.
the Pc has a 700 meghrtz celeron
512 meg memory
running mame 56 (I have both command line and windows version running)
« Last Edit: September 18, 2004, 11:18:24 pm by daywane »
maraxle
Re:what frontend to use on vertical cabs
« Reply #1 on: September 19, 2004, 08:28:47 am »
Game Launcher and AdvanceMenu both work well in vertical mode.  Game Launcher is the easier of the two to configure, but is less customizable.
daywane
  • GRRRR!
« Reply #2 on: September 19, 2004, 01:20:19 pm »
Thanks I tried advancemenu last night.  Its a bit over my head.  :-\
I just got Game Launcher running.  ;D
seems to be eather mame's gui or game launcher.
koolmoecraig
    • My Intervention
« Reply #3 on: September 20, 2004, 03:03:46 am »
Use Ultrastyle.
Looks great and it's a piece of cake.
No frills and great support from Chris.
peace
Craig
« Reply #4 on: September 20, 2004, 06:55:22 am »
It will, if you make a vertical layout ;)
That said I don't recommend it, at least until you've tried the FE's with built-in rotation.
maraxle
« Reply #5 on: September 20, 2004, 07:26:29 am »
Use Ultrastyle.
It's a little choppy on the 700 mhz machine I tried it on.  Plus you have to install that whole Windows thing.  It's not so choppy once it gets going, but when it starts and when it comes back from a game it just sits there for a few seconds before it shows the name of the game under the screenshot.
koolmoecraig
    • My Intervention
« Reply #6 on: September 20, 2004, 01:03:53 pm »
Try lowering the resolution.
On my vertical I run it at 640x480 and it works great. But then I have a 1.25ghz.
maraxle
« Reply #7 on: September 21, 2004, 07:14:03 am »
I can't go much lower than 640x480...
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« Reply #8 on: September 21, 2004, 11:00:02 am »
vertiwah is not that difficult to get to run, you should give that another try.  You do need to either get or create a skin.
daywane
  • GRRRR!
« Reply #9 on: September 21, 2004, 09:40:39 pm »
From what I saw on vertiwall I have to set it up in the comand line
I know nothing about comand line. or dos
Mamewah was EZ . I was able to cut and past in the ini file with note pad. very simple.
I tried this with vertiwah and got no change.   ???
daywane
  • GRRRR!
« Reply #10 on: September 21, 2004, 09:53:13 pm »
I just bumped into this. On this PC, ( my mane PC,  just built it a few months ago.) My video card will flip the screen also. I do not have mame or mamewah on this pc. would my video card flip mamewah. or will it be like Pivot Pro and only window is fliped  ???
I am using onboard vide on my vertical cab , ( no agp slot ) if a pci slot  ati video card will flip mamewah and give me more options on skins  I think I could sping for a new video card.
« Last Edit: September 21, 2004, 09:53:55 pm by daywane »
« Reply #11 on: September 22, 2004, 05:39:20 am »
Your hardware rotation will effectively do the same as PivotPro, but hardware rotation is MUCH preferred!  So you should be able to use your video card's rotation and a vertical MW layout.
daywane
  • GRRRR!
« Reply #12 on: September 22, 2004, 08:01:41 am »
ok. I can deal with that.
I do like the classic vertical skin , just not the mame logo. I tell ever one about mame and always help set them up. I am just not into having mame's logo on the cab. I prefer it to be hidden
Thanks for the help
« Reply #13 on: September 22, 2004, 11:12:47 am »
Thanks for the help
I don't have the MAME logo on my cab either.  Just make your own layout using the Layout Designer - job done :)
ultrastyle
  • Last login:October 20, 2023, 09:52:29 pm
    • ultrastyle MAME Front-end
« Reply #14 on: September 22, 2004, 10:38:48 pm »
This is actually by design, it waits for the intro music to finish, and during that time it doesn't write to the screen. I didn't realize anyone saw this as being an issue. I could easily change this around, if your not getting to your games fast enough.. I'll have a look at it.
Chris
Update: I have removed the delay from the start of the fe. I have also added a few other things. Look for a new release by the end of the weekend.
« Last Edit: September 30, 2004, 12:43:16 pm by ultrastyle »
