Author Topic: Help needed with monitoridentification  (Read 1299 times)
Trillian
  • Last login:August 19, 2004, 11:17:54 am
  • I will take the ring, though I do not know the way
« on: September 18, 2004, 01:38:19 pm »
Hi,
just baught a cab in Germany and I cant find the tip of monitor anywhere.
I have to pics here of the labels on the monitor and the chassis.
If someone could identify it for me,that would be a great help !!!
Thanx a mill!
« Last Edit: September 18, 2004, 03:12:14 pm by Trillian »
Trillian
Re:Intervideo - is that my monitor?
« Reply #1 on: September 18, 2004, 01:38:48 pm »
pic 2
Bally
  • Last login:March 10, 2012, 10:19:24 am
  • Pinball and Arcade Tech
    • Flipperspill
Re:Help needed with monitoridentification
« Reply #2 on: September 19, 2004, 09:47:09 pm »
Yes, that is it  :)
Your monitor is an Intervideo.
Trillian
« Reply #3 on: September 21, 2004, 02:09:45 am »
Thanx!
Do u or anyone know,if they make a good Mame monitor?
Would u suggest a Jpac or an ArcadeVga card?
Or both of them to run it?
I have no way of testing it, except if I buy a jamma board and plug it into the machine.
Or order one of the 2 above...
Anyway, the first question is my main one!
Because if the Intervideo doesnt work well with my PC, its pointless ...
Trillian
« Reply #4 on: September 22, 2004, 04:55:32 am »
Is it possible to do this VGA to Arcade Monitor hack like described on this page:
http://dragonsden.emuunlim.com/ddvgatutl.htm
He took a monitor extension cable and connected it from a, as i understand normal, graphic card to the Arcade monitor.
In connection with ArcadeOS or advanvemame would that be possible to do for me?
I dont fully get what he exactly does, but i think its worth a try.
Would that be an alternative to a J-Pac?
Whats the best solution?
cheap would be nice ;-)
Please post some suggestions!
Thanx...
here is another pic of the chassis, just to make sure, this really is an Intervideo moinitor(didnt find anything on them though =()
sac01
  • Last login:February 27, 2016, 08:15:22 am
« Reply #5 on: September 30, 2004, 07:28:26 pm »
 :o
OMG!
If this was IRC. I'd kick you
sac01
« Reply #6 on: September 30, 2004, 07:34:46 pm »
BTW, yeah you should have no problem hacking a normal vga cable to the r,g,b,sync of the monitor.  You should find plenty of diagrams on here and the web to show you just which pins you want...
  If your gonna use a 'normal' graphics card, you'll need one that can output at 15khz.  I use an old ati rage128 in one of my cabs with AdvanceMame, and AdvanceCab...You'll need to run some kinda software like this, or Powerstrip to adjust the videocard rates.
 A far easier way to go is get Ultimarc's ArcadeVga card.
hope that helps
sac
