Author Topic: Has anyone here built and used Bob Roberts' SafeBack discharger?  (Read 2592 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: September 17, 2004, 07:47:07 pm »
Hey,
I need to discharge a monitor, and like most first-timers to doing that, I feel very nervous about it. I followed Bob Roberts' plans on building his "SafeBack" discharger, but now I'm nervous about if I didn't build it right!!!
Anyone here use it? Should I wear rubber gloves when I use it?  ;D
Ray B.
NO MORE!!
SirPeale
  • Green Mountain Man
Re:Has anyone here built and used Bob Roberts' SafeBack discharger?
« Reply #1 on: September 17, 2004, 07:50:04 pm »
I've never done it.  What I do is take a length of wire, attach it to a flathead screwdriver, put an alligator clip on the other end.  Clip to the monitor frame, and slip the screwdriver under the cap.
RayB
  • There's my post
    • RayB.com
« Reply #2 on: September 17, 2004, 08:28:14 pm »
Hmm! Well that's basically what Bob's discharger is. Except his instructions have us drill a hole through the screwdriver with the wire inserted and heavily soldered. I think the reason for that is that you are taking a risk if your clip should happen to get knocked off atthe same time as you are discharging.
OK, I guess I will be safe with this method then!
NO MORE!!
XtraSmiley
  • Last login:November 02, 2024, 06:07:19 pm
  • Kill the Big Dog
« Reply #3 on: September 17, 2004, 09:47:21 pm »
I built and used the BR one about 1 month ago, it worked great and I even heard the static pop sound.  Hope this helps you.
hearingprotectionBIGDOG@yahooBIGDOG.com
Kill the Dog man.
l8nite
  • Last login:February 22, 2014, 09:12:14 pm
    • l8nite.net
« Reply #4 on: September 18, 2004, 01:23:21 am »
I too built one of the bob roberts one, except I couldn't drill through the screwdriver I bought (something about titanium being stronger than steel or somesuch... heh).   I ended up grinding a nice groove around the shaft using a grinding wheel and then wrapped/soldered my wire directly to it that way.  It has worked perfectly on several monitors now
sonicflood
  • Last login:August 19, 2005, 11:22:40 pm
« Reply #5 on: September 18, 2004, 09:41:10 am »
I used a jumper cable and clipped one end to the frame & a screwdriver to the other end.  Slipped under the cap and.. it worked great!
"Oh, you should never never doubt what nobody is sure about." -Willy Wonka
RayB
  • There's my post
    • RayB.com
« Reply #6 on: September 20, 2004, 12:01:04 am »
Well guys, I am back from the hospital now. They say I'll slowly regain use of my arm in about 6 months.
NO MORE!!
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
« Reply #7 on: September 20, 2004, 01:42:20 am »
YIKES! I hope you are not serious :-)  I have a monitor I too am going to discharge this winter when I get a chance to do some work on this machine I have, so don't scare me like that or I'll be wearing a rubber suit when I do it haha
fredster
  • It's all good!
« Reply #8 on: September 20, 2004, 08:53:12 am »
I use a screwdriver with a clip on the frame too.  I tried to build bob's but I lost interest after the drill broke.  The clip works fine. I've used it dozens of times in G07's and a couple of wells garners.
It's pretty freaky discharging the flyback the first time.  But after a while you get used to it.  I like to hear that pop.  If the monitor is cold, it won't pop or make any noise.
I suggest you make sure you hit the wire and leave it on there a few minutes before you remove the chassis.   If not, then discharge it and then wait about 3-5 minutes and then do it again.
Also, be careful of that big cap on the board.  It can bite too.
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« Reply #9 on: September 20, 2004, 09:48:17 am »
one thing.... if the monitor has a hv rectifier, you could blow it.  (You can build a small circuit  to protect it)
Its very easy to tell if you have one because it will be in line ( big red wire the runs from the flyback to the cub )
RayB
  • There's my post
    • RayB.com
« Reply #10 on: September 20, 2004, 11:41:14 am »
I was joking.
Um one thing I'm not clear on, when i slide the screwdriver under the cup, do I then take the cup and anode OUT? or am I supposed to leave it in?
If I take it out, what do I do to "discharge it again" as people suggest? Do I just waggle the screwdriver in the hole in the tube??
~Ray B.
NO MORE!!
SirPeale
« Reply #11 on: September 20, 2004, 11:48:51 am »
I was joking.
Yes, and yes.
XtraSmiley
  • Kill the Big Dog
« Reply #12 on: September 20, 2004, 12:53:12 pm »
I was joking.
Yes, and yes.
YES and NO!
After you slide the screw driver under there, wait about 2-3 min. then do it again.  If you don't hear a sound the second time (a pop or a sizzle) then you can remove the suction cup and there is NO need to stick the screwdriver into the hole at all!  If on the 2nd time you still hear a sound, wait another 2-3 min and do it again.
« Last Edit: September 20, 2004, 12:54:06 pm by XtraSmiley »
Kill the Dog man.
Rocky
« Reply #13 on: September 20, 2004, 02:01:17 pm »
I was joking.
Yes, and yes.
YES and NO!
Sorry, but you are wrong, XtraSmiley .
Please discharge the monitor again before you hook it back up.  I learned the hard way. I was re-attaching the suction cup and using a screw driver to squeeze the clip together and my hand slipped from the handle of the screw driver to the metal shaft.  Wow, talk about a jolt!
I'm sure it wasn't full voltage, since I had discharged it already, but for some reason, a charge can build again. In my situation it had been several hours that the monitor was sitting.
Anyway, even if you've discharded a monitor, go ahead and do it again just before you mess with the suction cup.
Rocky
Hoagie_one
  • Um....whats a cabinet
« Reply #14 on: September 20, 2004, 03:21:58 pm »
i dont know about you guys, but id wear rubber gloves anyways, lol
XtraSmiley
  • Kill the Big Dog
« Reply #15 on: September 20, 2004, 04:03:57 pm »
Rocky
Oh, sorry dude, yeah I never thought of that b/c I never had any problems with hooking it up later, I thought he meant during the disconnecting part.  You only have to do it the way I described.  Now after you are done hooking it back up, I've never done it again but I'll take your word that it's not a bad idea, you just have to be really carful to not scratch the glass.
Kill the Dog man.
