Author Topic: Mad Catz Dreampad without Pre-drilled holes?  (Read 2589 times)
J_Talbain
  • Last login:April 23, 2003, 06:42:49 pm
« on: September 05, 2002, 09:55:29 pm »
Recently I bought a mad catz dreampad (orange shell with blue grip accents) off of ebay.  I opened it up and noticed that there were no holes on the pcb like there were on the ones on websites.  Also, the contacts were much smaller.  Anyone else have a dreampad like this?  If so, do you know if anything has changed (common ground, wiring problems, etc.) with this control pad from its counterparts?  Thanks in advance.
CD_Vision
  • Last login:January 23, 2010, 10:01:56 am
  • Link sez it all
    • CD_Vision's Arcade Controls
Re:Mad Catz Dreampad without Pre-drilled holes?
« Reply #1 on: September 05, 2002, 11:37:30 pm »
I doubt anything has changed, but you can send me a scan to look at for you if you like.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #2 on: September 06, 2002, 12:58:36 am »
I've herd of people getting this verison of the madcatz pad also.  It should still be hackable (just not as easy as the original madcatz one).  Use a multimeter to verify the ground and button contacts.
-Dave
phantompower
  • Last login:June 14, 2024, 01:20:45 pm
  • The Game is NOT Over!!
    • MameStation
« Reply #3 on: September 08, 2002, 02:03:01 am »
This is the one of many Dreamcast sticks I soldered.  Definitely doable, but have good eye site.  You need to visually trace the paths to that central point you solder from.
Hope this helps.
Chuck
