Author Topic: WG D9200 at 38Khz?  (Read 1328 times)
Effayy
  • Last login:August 18, 2006, 02:09:07 pm
  • Slowest....Cab Builder.... EVER.
WG D9200 at 38Khz?
« on: September 14, 2004, 10:53:30 pm »
I'm currently looking over the WG website, knowing that I will most likely be buying a D9200.
Looking at their list of monitors, I see that there are 3 seperate models of the D9200.  the first is rated for 15/25/31 Khz, the second is only for dedicated Golden Tee cabs, but the THIRD. aaah the third.  It states it's 15/25/31/38 Khz.  It also sells for $15 more than the 31Khz version.
Since the 38khz monitor doesn't have a spec sheet on the website, I'm wondering if someone with experience on this specific model can answer the following:
1) Will it support 800x600 happily
2) Does it have the same hookup as the standard 31Khz version? (VGA cable that will connect direct to PC)?
3) The website says it's set up for 31/38Khz but will run 15/25Khz as well.  is it a pain in the rear to tweak it for the 15/25Khz resolutions?
Although I'm not technically expecting to run 800x600 for anything MAME-related, it's nice to know that the option would be there for $15 more.  But if there's a downside to buying this model, please fill me in.
A link to the 15/25/31Khz model:  http://www.wellsgardner.com/wellsgardner31/finditem.cfm?itemid=691
A link to the 15/25/31/38Khz model: http://www.wellsgardner.com/wellsgardner31/finditem.cfm?itemid=1539
- FA
Dariusz
  • Last login:November 23, 2018, 02:41:36 pm
Re:WG D9200 at 38Khz?
« Reply #1 on: September 16, 2004, 04:55:19 am »
I like to know too.
Dariusz
shadowdrak
  • Last login:November 20, 2005, 04:59:54 pm
  • I'm still a llama!
« Reply #2 on: September 18, 2004, 01:55:42 pm »
That new?  never saw it on their site before.  Guess maybe it is their answer to that Kortek monitor.
