Author Topic: [ PROBLEM SOLVED ] V-Hold not stable - arcadevga + jpac on nanao/sega 26"  (Read 4279 times)
breech
  • Last login:November 17, 2006, 09:19:03 am
Everythings fine except for the vertical scrolling. i can adjust the v hold but it eventually starts scrolling again.
the v-h- (composite),v-h+, v+h-, v+h+ (garbled display) switches dont help as they dont lock the hold. any ideas?
also which switch position should i be using?
cheers
« Last Edit: September 14, 2004, 08:18:45 am by breech »
P3 800EB, 128@133, 6g, Awe64, ArcadeVGA, J-Pac, Nanao (Sega) Chassis, 26" Mitsubishi in Allied Industries NBA Jam cab...
MrArcade
  • Last login:May 29, 2025, 02:06:06 pm
  • I wish I had time to play these games !!!
Re:horiz hold problem on arcadevga/jpac on nanao/sega 26"
« Reply #1 on: September 12, 2004, 03:14:18 pm »
How do you have it wired?
Oh, the memories of living on pizza subs and Dr Pepper...
breech
« Reply #2 on: September 13, 2004, 05:03:44 am »
arcadevga card -> jpac - Jamma harness (power supply is on)
i guess my monitor requires a different synch.
any suggestions?
menace
Re:please help !! V-Hold not stable - arcadevga + jpac on nanao/sega 26"
« Reply #3 on: September 13, 2004, 07:34:17 am »
What pin(s) on the monitor (v-, h-, v+, h+) is wired to the
v. sync line coming into the jamma harness?  for the WG K7191 I had to wire V- AND H- to the v. sync on the jamma harness for stability.
breech
« Reply #4 on: September 13, 2004, 08:04:18 am »
k. jamma pin 13 (white) goes to a 6 pin header with the 3 RGB cables & gnd
1= V.D (none)                 (PDF says yellow??)
2= H.D sync (white)
3= GND (black)
4= B
5= G
6= R
.. there is no mention of +/- in the manual & i cant see much in the chassis. what am i looking for exactly?
« Last Edit: September 13, 2004, 08:54:24 am by breech »
breech
fixed v-hold
« Reply #5 on: September 13, 2004, 08:55:24 am »
i tied the vga h & v syncs together & v-hold is behaving correctly (like a TV)
i soldered a switch & ribbon cable to pins 13 & 14 on the j-pac vga connector.
if you have the same problem with v-hold not snapping to top/bottom of screen, let it roll slowly, use a small screwdriver & carefully short pins 13 & 14 on the j-pac.
see if the v-hold locks when it gets to the top or bottom.
SOLDER SIDE OF VGA CONNECTOR:
05-04-03-02-01- soldered pins
-10-09-08-07-06 soldered pins
15-14=13-12-11- soldered pins << carefully short pins 14 & 13 & v-hold should lock.
-------------------- pcb edge
15-14-13-12-11- gold pins
-10-09-08-07-06 gold pins of vga connector
05-04-03-02-01- gold pins
« Last Edit: March 29, 2005, 06:00:13 am by breech »
