Author Topic: Help on Iso xformer and VGA hack  (Read 1155 times)
Ash...Housewares
  • Last login:August 12, 2006, 02:47:09 pm
  • Who wants some?!
« on: September 06, 2004, 03:44:28 pm »
Basically, I just don't want to fry my monitor so I'm going to be extra careful.
Below I have attached 3 pictures that explain what I'm hooking up.  I'd like reassurance that I'm doing it right.
Oh, and this is a WG7131 monitor.
Let me know what you think!
On the VGA hack I'm not sure if it would be beneficial (or harmful) to me to hook up the ground on the -sync side to pin 10.  I'm also not positive that I should use the -syncs instead of the +syncs.
-Ash
« Last Edit: September 06, 2004, 06:30:19 pm by Ash...Housewares »
"Sure, I could have stayed there.  Could have even been king.  But in my own way, I am king.  Hail to the king baby."
menace
Re:Help on Iso xformer and VGA hack
« Reply #1 on: September 07, 2004, 06:57:28 am »
Looks ok--although you should maybe have the case for the isolation transformer on the same ground as what you are calling the outlet ground.
I think the - sync's are what you want to wire for this monitor. You can either twist them together to make a composite sync or wire them individually (depends what wires your cable hack has)  Also the 2nd ground in your picture (pin 10) is a redundant one--you can hook it up as well but its not necessary
Ash...Housewares
  • Who wants some?!
« Reply #2 on: September 07, 2004, 05:10:27 pm »
So I should connect the outlet ground from the monitor to the chassis of the isolation transformer, then connect the chassis of the transformer to the outlet ground?
« Last Edit: September 07, 2004, 05:14:19 pm by Ash...Housewares »
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: September 08, 2004, 05:36:37 pm »
The metal frame of the monitor should be connected to outlet ground. The two ground pins on the connector are one and the same, they are linked on the PCB so it doesnt really matter which you use. They should be connected to the signal ground of the device driving the monitor (vga card)
It is good practice to ground he transformer case as menace mentioned.
