Author Topic: Help on cabinet door please!  (Read 4465 times)
DJMagic
  • Last login:September 02, 2002, 12:03:49 am
« on: September 02, 2002, 12:12:03 am »
I'm almost finish my VERY FIRST cabinet!  ;D yeah! o wait... :-\ how can I put my front door up!? uh...hmm... :-\ can someone help me out? Also If I want to add a coin door to it is it hard to install and hook up? where is a good place to purchase one?? ::) Thanks!!
Smack
  • Last login:May 07, 2013, 11:40:41 pm
  • Who changed my avatar?
Re:Help on cabinet door please!
« Reply #1 on: September 02, 2002, 12:14:58 am »
You'll just have to cut a hole in the cabinet to fit the coin door. As far as wiring goes, its a piece of cake, its just microswitches that register the credits. If you've been able to hook up arcade joysticks, you won't have any problem.
Check out Happs for the coin door mechanisms...
http://www.happcontrols.com
Good luck!
Smack
Never Let Donkey Kong Use Your Toilet.
(We're talkin' big processed brown bananas...)
Somebody out there stole my sig! LOL
DJMagic
« Reply #2 on: September 02, 2002, 12:40:56 am »
Thanks! Smack!  ;D Also do you know where I can find the door hinges that will work for arcade cabinet? I tried normal door/cabinets hinges...can't get the door open :'(
« Last Edit: September 02, 2002, 12:41:43 am by DJMagic »
SNAAAKE
  • -Banned-
« Reply #3 on: September 02, 2002, 01:24:24 am »
MAN,
just go to hardware store and ask for kitchen door hings..
HOMEDEPOT  :)
Smack
« Reply #4 on: September 02, 2002, 02:56:18 am »
Happs may have something  comparable to the door hinges. Like Snaaake said, check out a home depot.
I know that on my upright cab, regular hinges won't work. On my Balle/Sente cab, the cabinet is wood but the door on the cab in the front is metal. The hinges are welded to the door, then screwed into the wood of the cabinet from inside.
(The door I'm talking about  is a front access door, separate from the coin door.)
On a coin door, the hinges are part of the whole piece. You just have to cut the hole for the entire piece.
If you're dealing with a metal access door, you may consider re-fitting the cab with a wooden door, there's tons of hinges that you could use then.
It's kinda touch to tell what you're looking for. Do you have a pic of work in progress?
Word.
« Last Edit: September 02, 2002, 02:58:08 am by Smack »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #5 on: September 02, 2002, 04:39:38 am »
How do hinges hinder you from openning a door?  You are talking about the coin door?  You didn;t get a real arcade coin door then?  What are you trying to do?  Maybe someone has a better idea...
chanson
  • Last login:August 21, 2003, 01:09:57 pm
  • Finished 1 MAME machine, working on #2!
« Reply #6 on: September 02, 2002, 09:48:32 am »
Sounds like we need a bit more information.
Are you talking about the door to the front of your cabinet, or about the coin door itself?  If you're talking about the door to your cabinet, we may need pictures to help.  Mine (home built cabinet) uses special hinges from Home Depot that allow none of the hinge to show at all.  If that's the kind of hinges you need, I can look at the package (I have a new set in the garage) and tell you the name.
DJMagic
« Reply #7 on: September 02, 2002, 07:49:38 pm »
Here is the type of hinges I'm looking for...my cabinet door looks just like this one.  ???http://home.earthlink.net/~seanhat/arcade/coindooropen25.jpg
http://home.earthlink.net/~seanhat/arcade/coindoorfront25.jpg
BobA
  • What Me Worry?
« Reply #8 on: September 02, 2002, 08:26:50 pm »
I have similar doors on an old Atari cab.  You dont need hinges as they are part of the door assembly.  The doors come in a frame with hinges attached.  You have to cut a hole and mount the whole assembly with the mounting bits that they provide.
BobA
DJMagic
« Reply #9 on: September 02, 2002, 09:41:11 pm »
BobA, when you said a part of the door assembly...are you talking about the "Coin Door"?? If so where can purchase it? I check Happ Controls web site they got the coin door I want, but didn't see any frame with hinges attachment for my wooden cabinet. I would like the make my cabinet door open like the one showing in the pic. (Just in case someone haven't notice, those are not my cabinet)  :D
http://www.happcontrols.com/images/40/40003800_new_exploded.gif
http://www.happcontrols.com/images/40/40003800_color.jpg
« Last Edit: September 02, 2002, 09:42:19 pm by DJMagic »
BobA
  • What Me Worry?
« Reply #10 on: September 02, 2002, 09:59:59 pm »
If you look at the color picture you supplied you will see the hinge assembly on both doors.  The doors have locks on them and open and close in separately in the larger frame or assy.  The hinges are piano type and go the whole left side of each door.
BobA
DJMagic
« Reply #11 on: September 04, 2002, 05:04:48 am »
BobA, I'm not looking for the hinges that is on the coin doors...I'm acutally looking for the hinges that connect my wooden door with coin door on it to my cabinet. I don't think I explain too well...sorry.. this is the hinges I'm looking for...
(The silver hinges showing in this picture that connect the wooden door to the cabinets)
I haven look all the hardward store local..no one has it... :'(
Bursar
  • Last login:September 14, 2005, 06:57:07 am
« Reply #12 on: September 04, 2002, 05:42:22 am »
They don't look like hinges, more like L brackets.
If I've read you right, the coin door has the hinges and it just needs bolting to your cabinet.
I'm not going to be using a coin door, so don't know a huge amount about them, but it does look from the pics you've supplied that you just need to cut the right size hole in the front of your cab, and then bolt the coin door into place.
Bursar
« Reply #13 on: September 04, 2002, 05:47:22 am »
Ah, I think I see what you mean. near the bottom corner of the door is a silver hinge.
I missed that first time round.
It looks like a kitchen cupboard hinge. If you open your kitchen cupboards you should see one similar.
I would imagine most DIY shops would sell them, if not, goto a place that sells flat pack kitchen units and ask if they have a couple of hinges spare that you either have for free/real cheap.
Failing that, dismantle your kitchen cupboards! :D
Those doors only slow you down when you're diving in for food anyway ;)
DJMagic
« Reply #14 on: September 05, 2002, 02:21:47 am »
Ok, I'm not trying be lazy or something...I been to all the major DIY hardware store today....believe or not. Not one sells the hinges that I'm looking for. Does anyone know where I might be able to get one online? :-\
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #15 on: September 05, 2002, 08:42:23 am »
What hinge have you been looking for?  To me, the pic looks like it could be a Euro hinge but it is really hard to tell because the hinge is so small in the picture.  If you want to buy hinges online you could try Rockler.com.
DJMagic
« Reply #16 on: September 06, 2002, 02:28:50 am »
WOW! JustMichael, that is what I was looking for! Yeah! ;D Thanks guys! I'm putting an order in right now...I'll let you guys know how my cabinet looks once I'm done! THANK YOU ALL!!!  ;D  ;D
