Author Topic: Cheapest place to buy spinners?  (Read 2492 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: September 02, 2004, 04:29:04 pm »
Can I buy one for cheaper than $33.89 shipped?
Oscar controls are $59 for the "Vortex" model, and that doesn't include the spinner.  I think I'll wait to see if I use it much first.
http://www.cheeptech.com/cuspin.html - $59
http://mamespinner.com/ is $33.89.
TheNasty was selling them for $18 shipped, but has anyone seen him lately?
I'd consider building/hacking one together, too.  Found these:
http://www.twistygrip.com/spinners/spinners.htm
http://www.gearheadlabs.com/spinner/
and of course:
http://www.arcadecontrols.com/arcade_spinners.shtml
MasTequila
  • Last login:November 13, 2004, 12:07:53 pm
  • I'm a llama! Here me roar!
    • GameTruth
Re:Cheapest place to buy spinners?
« Reply #1 on: September 02, 2004, 04:42:25 pm »
I saw the nasty on earlier today, you could send him a PM.  Anyway in the project announcements he has a tutorial of how to make your own.  I would look at that because the parts needed to make it are very cheap.
~Mas
Stormy151
  • Last login:June 11, 2011, 01:57:24 am
  • It was Dick Jones! DICK JONES!!!
« Reply #2 on: September 02, 2004, 05:38:32 pm »
The cheapest route would be to build your own.  Maybe check all the different spinner tuts and combine them into one, if you can't get all the parts one tut requires such as hard drive bearings.
I remember Nasty's tut as being very good.  If it were me, I'd do the Nasty.
Wait, that didn't sound right... ;)
spystyle
Re: Cheapest place to buy spinners?
« Reply #3 on: February 21, 2005, 11:23:51 am »
I figured out how to make one for $10 that works great, based on Nathan Strums Cheep Spinner, see my pic here:
http://spystyle.arcadecontrols.com/files/cheep_spinner_lite.jpg
Dig it?
Craig
« Last Edit: July 12, 2005, 03:04:06 pm by spystyle »
Hoagie_one
  • Um....whats a cabinet
« Reply #4 on: February 21, 2005, 12:00:40 pm »
i have a couple hard drive bearings if you want to make your own
Chris
    • Chris's MAME Cabinet
« Reply #5 on: February 21, 2005, 12:02:45 pm »
But the difference is going to be quality.  The Vortex vs. mamespinners.com is like the difference between a Happ's Suppr joystick and a plastic PC joystick from CompUSA.
--Chris
Dougmeister
  • Dig-Doug
« Reply #6 on: February 21, 2005, 04:29:27 pm »
Thanks for all the ideas.  Ended up buying one from TheNasty.  He did a nice job.
Dougmeister
  • Dig-Doug
« Reply #7 on: February 22, 2005, 08:12:18 am »
Tried to drill a small hole then route one end, got tired and just ended up drilling a big hole :)
spystyle
« Reply #8 on: February 22, 2005, 08:44:22 am »
I can dig it,
I  like my spinner as it only requires a 3/4" hole, which can not be seen with the spinner knob over it. Can you see the hole below your spinner knob?
So far none of the DIY spinner plans were very wood mounting friendly, I think I'm on to something with the above plan...
Chris
« Reply #9 on: February 22, 2005, 08:54:17 am »
--Chris
spystyle
« Reply #10 on: February 22, 2005, 09:20:45 am »
My above plan, based on the Cheep Spinner, dosen't need any superglue! I wonder if you are thinking of the Quickspin spinner, which uses superglue and relies on a small sleeve bearing (junk)
Here's the Cheep Spinner:
http://www.arcadecontrols.com/files/Miscellaneous/spinner.pdf
Here's the QuickSpin Spinner:
and my Cheep Spinner lite:
I think Nathan Strum was brilliant in finding the porch door roller ($2.50, a ball bearing assembly with a 1/4" shaft, the magic diameter for spinners) and the steel tie plate, (50 cents, full of holes, makes a non-flanged bearing easy to mount in wood)
As you'll see in his tutorial though, he makes it more complicated than it has to be. Solder/weld simplifies his design, and reduces the cost as no machine screws are needed.
Dig it?
Craig
« Last Edit: July 12, 2005, 11:49:30 pm by spystyle »
Chris
« Reply #11 on: February 22, 2005, 09:45:05 am »
My above plan, based on the Cheep Spinner, dosen't need any superglue! I wonder if you are thinking of the Quickspin spinner...
Actually, it was not the Cheep Spinner, it was the TwistyGrip Spinner (http://arcadecontrols.com/files/Miscellaneous/Twisty-Grip_Spinner.pdf).  I apologize for impugning the reputation of the Cheep Spinner.  :)
--Chris
--Chris
quarterback
-- Chad Tower
Chris
« Reply #13 on: February 22, 2005, 11:40:55 am »
So Chris,
Build my spinner, it's only $10 :) and I would be honored if the jukebox gawd built something I thought up!
I'm not seeing what holds the fender washers in place.  Is it just gravity and friction?
--Chris
spystyle
« Reply #14 on: February 22, 2005, 12:42:23 pm »
Hi Chris,
I've updated the picture showing the side view, which reveals that everything is held tight by (3) 1/4" nuts.
Dig it?
Craig
