Author Topic: Xarcade KVM?  (Read 1194 times)
matt.e
  • Last login:September 02, 2004, 02:45:56 pm
Xarcade KVM?
« on: September 02, 2004, 02:49:29 pm »
Hi,
Does anyone know if i could use an old KVM switch to switch between my DreamCast and MAME PC (using the serial mouse port on a KVM for the Xarcade)?
My DC runs through my monitor anyway so it would be great if they would both work with a KVM (and it would make a very nice mame/DC cab project in the future).
thanks if you can help,
matt.e
Why don't they just leave me alone!
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
Re:Xarcade KVM?
« Reply #1 on: September 02, 2004, 04:56:54 pm »
i looked at this type of setup and xarcade requires a full power down when switching systems...   i.e. swtiching a kvm would not work unless u pefectly stop for 2 seconds in the middle of the switch (power down)
you can't have a temp switch with out anything hooked up (rep from xarcade told me this)
i didn't ask if the temp position was in the middle... saying you have switch A  /   B    / C
dreamcast =  A
nothing = B
PC/Mame = C
hmm...that could work now that i'm thinking about it.. my other example to xarcade was at the end (last connection)  I would shot an email over to them, they will answer your questions for you..
matt.e
Re:Xarcade KVM?
« Reply #2 on: September 03, 2004, 02:08:55 am »
responce from Xgaming:
A serial switchbox, yes. But you have to have an empty spot between the 2 devices. For instance have PS2 on channel A, and XBOX on channel C. Nothing on B.
thanks for your help. i'm gona give it a try...
matt.e
