Author Topic: How much does an awl help for accurate drilling?  (Read 1114 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: September 02, 2004, 07:11:33 am »
Just wondering if anyone here has used an awl to create marks for drilling on your cp? Does this help with accuracy? The last panel I made, I found that I made of lot of drilling errors, where I was off ever-so-slightly (but enough to be a problem)
somunny
  • Is it hot in here?
Re:How much does an awl help for accurate drilling?
« Reply #1 on: September 02, 2004, 08:58:10 am »
I normally drill a very small pilot hole first, rather than using an awl or centerpunch.
Pre-marking the hole couldn't hurt, unless *that* mark is off, as well.  ;)
DougHillman
  • Last login:September 13, 2004, 07:39:18 pm
« Reply #2 on: September 02, 2004, 08:59:58 am »
You'd even consider drilling without premarking the holes?  ;)
I don't use an awl, but always mark the holes first.  Whatever sharp object laying around becomes my awl.  Phillips head screwdriver, screw, nail, whatever.
Print a full sized template, tape it on your CP blank, and mark ALL your holes first.  Couldn't imagine doing it any other way.
D
If you can't be a good example at least try to be a horrible reminder.
« Reply #3 on: September 02, 2004, 12:12:18 pm »
I normally mark first (also with what ever comes to hand ;) ), but I think it depends on what you're drilling...for instance, MDF 'dents' as soon as you lean on it with a small drill bit, so I tend to just do that while I'm about to start drilling a pilot hole.
Metal of course is another matter...
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #4 on: September 02, 2004, 03:29:19 pm »
The kind of bit you're using makes a difference too. Twist bits tend to wander, while forstner bits don't. Spade bits can on pine when the grain is very pronounced (or if there's a knot).
Whenever possible I clamp my work on the drill press, and then it's just a question of alignment  ;D
Bob
