Author Topic: Jukebox nearly finished - more photos  (Read 27817 times)
rob1234
  • Last login:September 23, 2022, 07:40:58 am
Re: Combined Jukebox and Vpinmame project
« Reply #40 on: March 23, 2005, 11:29:56 pm »
sent you another pm
clonestar
  • Last login:March 09, 2009, 04:00:53 pm
  • Thunderbirds are puppets!
« Reply #41 on: May 02, 2005, 05:41:32 pm »
Got a bit more done in the last few days.
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
Re: Jukebox (and formerly Vpinmame) project new pictures
« Reply #42 on: May 08, 2005, 03:36:21 pm »
It looks nice, I like the flashing control panal lights.
Gary
quarterback
« Reply #43 on: May 09, 2005, 01:11:31 am »
This is awesome.  Really makes me want to put a jukebox together.
Looks great, clonestar!
-- Chad Tower
crashwg
« Reply #44 on: May 11, 2005, 07:59:00 am »
I hope you don't have any epileptic friends...  :P
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
clonestar
« Reply #45 on: May 22, 2005, 05:43:48 am »
After much consideration and some discussion here:
http://forum.arcadecontrols.com/index.php/topic,37025.0.html I have decided to make a fairly big change on my juke before it is even finished.
clonestar
Re: Jukebox (and formerly Vpinmame) project tmolding HELP NEEDED
« Reply #46 on: May 23, 2005, 03:09:37 pm »
Just bumping my last post as I still need an answer to the t-molding question, can tmolding (3/4 silver) be safely removed and re-installed or will I ruin it?
Bumblebounces
  • Last login:January 26, 2016, 07:57:28 pm
  • I ever tell ya 'bout Bumbles? Bumbles...BOUNCE!
    • Starbase 74
« Reply #47 on: May 23, 2005, 04:30:34 pm »
I have never done anything with the silver or chrome stuff but my experience with the regular black is that removing it does do some damage to the "teeth" on the T-tab (and sometimes to the slot, too).  I guess it also depends how wide a slot you cut.  I opted for a 1/16 inch slot (which is very tight) where some guys say 3/32 is better.  Anyway, it shouldn't be unusable after removal but it would be best to avoid needing to remove it in the future.  I always leave T molding as the very last thing.  I realize you are changing your design so you have no choice here.
Good luck
Bumble
clonestar
« Reply #48 on: June 07, 2005, 09:36:21 am »
Well the juke is finished from the front at least.  SInce the last post I have finished and fitted the drawer:
Since then I have replaced the keyboard with a mini illuminated USB keyboard but I haven't taken any more pictures as the wood into which the runners screwed has split and needs to be replaced, which in turn means replacing the felt covering, which means drilling out the rivets and removing the edging strip.
The item on the right is the active crossover which feeds the two main amps and is in the drawer so I can tweak a bit.  When I remake the drawer I will probably also and an illuminated switch to turn off all the hi-fi and lights for when i am using the pc.
This pic shows the front drawer closed with the key in.  I have bought a set of twenty identical locks from Suzo UK, which mean I can put all my pins and the juke on the same key (I also have 39 spare keys as a result)
The final touch for me was adding the screensaver version of GEISS (the old one available here: http://www.geisswerks.com/geiss/ ) I also tried bomb http://www.draves.org which was much more interesting , you can feed it your own images to work with, but I couldn't get it to line up right on the screen and in the end Geiss had more impact, heres some more pictures:
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
Re: Jukebox nearly finished - more photos
« Reply #49 on: July 26, 2007, 11:01:16 pm »
VERY IMPRESSIVE clonestar, you did a great job and it's really unique too.
I like the metal look and concealed speakers & lights.
Nice job on the CP as well, looks simple and well layed out.
Did you ever locate the name or a link to the light organs?  I tried your link above, but it said they have been discontinued. I've been trying to find something similar, but only found to cathode tubes and EL lights.
Again, GREAT job! :cheers:
MPTech
   Better living thru technology!   ;-)
clonestar
« Reply #50 on: July 27, 2007, 05:10:11 pm »
Hi MPTech - glad you liked it.  As for the light organs I don't know where you are but in the UK they often have something similar (slightly bigger) on sale at Cash Convertors or whatever the're called now.
MPTech
« Reply #51 on: August 15, 2007, 10:18:21 pm »
Clonestar, I'm still looking for the Light Organs.  I did find something like what you had, but they were "out of stock" / "discontinued". (I'm afraid it's probably discontinued).
Do you have a link for "Cash Convertors" or do they ship?  I'm in the US.
MPTech
Cyberflexx
  • Last login:October 12, 2012, 03:40:10 pm
« Reply #52 on: March 09, 2009, 02:20:19 pm »
Thats very nice!!  Good Job
clonestar
« Reply #53 on: March 09, 2009, 04:00:53 pm »
If anyone in the UK is interested I am now looking to sell this, I was going to dismantle it to use the parts in my new project but couldn't gring myself to do it!
Gatsu
« Reply #54 on: March 10, 2009, 04:59:52 pm »
dude that is a sweet juke.
I'd slap some Daft Punk on it for sure.
