Author Topic: Best Deal on wiring CP?  (Read 1860 times)
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« on: August 30, 2004, 06:03:05 pm »
My control panel originally used pre-wired buttons + joysticks that were part of an older cab I purchased; however, I have had nothing but trouble with these, so I recently purchased a Dream Arcades control panel set (2 joysticks, 12 buttons, 1P start, 2P start, all w/ switches) -
Question:  What is the best (economical & sturdiest) way to connect these to my I-PAC2?
So far I have looked at Peale's site for disconnects, wire, etc. but I cannot order anything off of his site (server migration?), Radio Shack, which I knew was already way too expensive, and the Ultimarc Wiring Kit, which looked good until you add the S&H  :P.  Which of these, or others, should I go with (I have no soldering experience whatsoever)
Wizard of DelRay
Re:Best Deal on wiring CP?
« Reply #1 on: August 30, 2004, 06:17:16 pm »
I got quick disconnects from Electronics Warehouse (probably local, but you might have a similar type of business where you live.)  Otherwise, you might want to try http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=50549&item=5713265419&rd=1&ssPageName=WD1V
paigeoliver
  • Awesome face!
« Reply #2 on: August 30, 2004, 06:18:40 pm »
Um, just go to the auto parts store, they will have all that.
sc1103
« Reply #3 on: August 30, 2004, 06:34:26 pm »
Thanks for the link to the cheap disconnects; however, the biggest concern is $$$ for the crimper - on a shoestring budget- what style/where should I get my crimper? Thanks!
Wizard of DelRay
« Reply #4 on: August 30, 2004, 07:07:50 pm »
Well, if you have a Harbor Freight near you, this is a cheap one http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=36810
itismejs
  • Last login:February 29, 2012, 05:25:43 pm
« Reply #5 on: August 30, 2004, 07:08:58 pm »
Radio shack has a wirestripper/crimper. They are ~$8. If you dont wanna spend anything you can try to use small plyers.
exibar
  • Last login:January 02, 2025, 11:38:59 pm
  • I'm the creator of Exibar's Lair!
« Reply #6 on: August 30, 2004, 07:26:40 pm »
Home depot or Lowes, they both have boxes of 100 connectors (way more than enough) for like $4 - $5 and their cheap crimper is like $4.... Thier expensive crimper is like $8 ish....
  They don't sell the 20 guage wire, Radio shack sells a nice 3 spool pack for like $5 comes with red, black, and green wire  something like 25 feet per roll or there abouts..
   Don't forget a small package of wire ties from home depot or Lowes too... those run a couple bucks for a bag of 100 or so.  I picked up 1000 of the little buggers for $12 at HOme depot....   Use scotch tape and a sharpie marker to label your wires (BOTH ends dude!)before bundeling them up with the wire ties.  or if you want to spend a couple bucks on a wire labeling sticker book, that will give your wire harness a nice professional look to it.
   I put the Player one buttons and joystick in the same bundle (wireing harness now <grin>) and the same for Player two.  NOT the ground wires though, leave that separate and run two wires to each connector and keep going on the like a string of christmas tree lights, except you'll have a string of quick connectors.
 for under $20 you can wire up your new control panel real nice nice, even with the wire marking sticker book :-)
  Take your time, do it up nice, and you'll never have to worry about your wiring :-)
  Mike B
Wizard of DelRay
« Reply #7 on: August 30, 2004, 07:40:48 pm »
If you're looking for .250.  I know here that I could not find .187 quick disconnects at neither Lowe's, Home Depot or Harbor Freight.
sc1103
« Reply #8 on: August 30, 2004, 08:05:59 pm »
Thanks again to everybody...prob. gonna go with Mike's instructions  :D and the ebay disconnects
mp2526
  • Last login:August 11, 2023, 02:30:47 pm
    • Miavio
« Reply #9 on: August 30, 2004, 08:49:40 pm »
One thing I find that helps with wiring is terminal barrier strips, useful for providing a common grounding point for all the switches.
You can get them fairly cheaply at my site http://www.miavio.com.  Click on the products link and then on the Electrical Accessories category.
« Last Edit: August 30, 2004, 11:22:21 pm by mp2526 »
exibar
« Reply #10 on: August 30, 2004, 10:23:25 pm »
  ahhh, yes I like the fully insulated disconnects, so I have to wind up getting th e.250's.  They work just as well with only a slight wiggle, but they hold tight and don't come off easily so I'm happy with them.
  Mike B
paigeoliver
  • Awesome face!
« Reply #11 on: August 30, 2004, 11:03:51 pm »
Once again, don't go to the hardware store, go to the auto parts store, they all stock .187s because that is a common automotive size.
And speak for yourself, I go through boxes of 100 way too fast.
