Author Topic: Illustrator Question re: Transparency  (Read 1897 times)
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
« on: August 30, 2004, 03:53:53 pm »
Been playing in Illustrator 10, btw Frosty?  Friggin Awesome Tutorial.
I'm nearly done with what I've been vectorizing, but I have two areas that I need to make completely transparent to the layer behind them, and I can't figure out how to do it.
Essentially, these are the area inside the letter "O" and the aread inside the letter "R" and I don't know how to get rid of that color area.
Help maybe?
GGKoul
  • Cheesecake Apprentice
Re:Illustrator Question re: Transparency
« Reply #1 on: August 30, 2004, 04:10:25 pm »
Try asking this in the Artwork section
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #2 on: August 30, 2004, 05:04:28 pm »
You can't make part of an object transparent, you need to cut a hole in it. In Illustrator 7 the tools you need are on the Pathfinder pallet. Make the hole as an object, and select the object and the hole, then click the pallet button.
Bob
rdagger
« Reply #3 on: August 30, 2004, 05:50:54 pm »
In AI 10 you can use an object to cut out a portion of another object.
To draw an simple O:
1.  Draw a circle.
2.  Draw a smaller circle and center it over the bigger circle.
3.  Select only the smaller circle.
4.  Click Object-Path-Divide Objects Below.
5.  Delete the smaller circle.
mahuti
« Reply #4 on: August 30, 2004, 06:54:27 pm »
What you are trying to do is to "create a compound path"
If you have letter 0, it is made of 2 lines, the outside and the inside. To make the inside "invisible" you need to create a compound path.
SO, choose the base of the object, hold "shift" and slect the invisible part, then choose "Object > Compound Path > Make"
There you go.
NinjaEpisode
« Reply #5 on: August 30, 2004, 09:06:16 pm »
Thank you gentlemen!
