Author Topic: Where to get wire harness for Mini-Pac  (Read 2065 times)
Edgedamage
  • Last login:October 06, 2018, 12:21:23 am
« on: August 29, 2004, 09:39:31 pm »
Just wondering where to get the parts to make my own harness for the Mini-Pac. I have found a IDE cable that I was able to seprate each wire with but 3" of wire is kinda short. My other option is to find a female 40 pin plug and solder a wire to each pin.
Pic of IDE hack.
« Last Edit: August 29, 2004, 09:47:42 pm by Edgedamage »
Curls in the squat rack !?!?!
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
Re:Where to get wire harness for Mini-Pac
« Reply #1 on: August 29, 2004, 09:59:46 pm »
why not just solder wires onto the ends of those?
Knoxximus
  • Last login:December 19, 2011, 12:22:58 am
  • Young Frozen
    • Beat-TECH Productions
« Reply #2 on: August 29, 2004, 10:39:17 pm »
....or crimp em, if you're up for that....
Dumb questions deserve dumb answers.
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #3 on: August 30, 2004, 02:42:11 am »
Just find a longer IDE cable, cut one end off and separate the wires as you have done on that one.  Then crimp some quick disconnects onto the ends of each wire and away you go.
I had to do that recently on a friends minipac as the wiring harness that comes with the minipac is way too short for a large panel.  Most local computer shops should have old IDE cables laying around out the back which they may let you have.  I managed to find one which was about 40cm long and only had the connectors at each end and it worked out great.
microwrx
  • Last login:July 06, 2008, 09:22:02 am
« Reply #4 on: August 30, 2004, 04:01:11 am »
Alternatively you could get a terminal block/strip, wire the IDE cable you have to one side and the button/stick wiring to the other side just like on an I-PAC.
Searcher7
  • Last login:June 21, 2009, 10:45:22 pm
« Reply #5 on: July 24, 2006, 11:30:54 am »
A someone elaborate on what a "terminal block/strip" is, and where to get one?
Thanks.
Darren
miles2912
« Reply #6 on: July 24, 2006, 01:43:13 pm »
Thanks.
Darren
Here is a link to one at radio shack
http://www.radioshack.com/product/index.jsp?productId=2103229&cp=&origkw=barrier&kw=barrier&parentPage=search
You can see my minipac just below the trackball and the barrier blocks to the left and right of it.  They worked out great.
D-
