Author Topic: dc vgabox mod...need a mentor in Northern NJ  (Read 3332 times)
tenex2mg
  • Last login:December 28, 2025, 09:27:07 pm
  • helllllllloooo Nurse
« on: August 29, 2004, 12:06:19 am »
Ok guys and Gals, after a rather dry few months I finally found a VGABox on Ebay.  Now before I open this one up and sacrifice it like the 8 or 10 that came before it, is there anyone in the Northern NJ area that has done this mod before and could asist me in the procedure.  Or even test it on their setup.  I know its just one wire, and believe me I am fairly intelligent...(just not that good of a speller) its just been too long for me to botch up again.
As Always,
Thanks.
Jeff
tenex2mg
Re:dc vgabox mod...need a mentor in Northern NJ
« Reply #1 on: August 30, 2004, 03:25:14 am »
ok, i tried hooking up the vgabox again, with both a "hacked" version and a "virgin" version.  both ways i got an image like this
i have it connected from monitor to switch box, then to vgabox and computer.  works fine with the PC but i get either that image or a bunch of lines?
any thoughts???
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
« Reply #2 on: August 30, 2004, 06:45:33 am »
Looks like a sync problem.  How many sync inputs does you monitor have?  If there's only one, you'll probably have to combine the H and V sync outputs from the VGA box.
If no one feeds the trolls, we're just going to keep eating your goats.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #3 on: August 30, 2004, 11:25:06 am »
If the hacked version of your VGA box works on your PC then you did not hack it correctly.  A hacked version can only output 15khz which is not sync'able on a standard VGA computer monitor.   Secondly, if the picture on your arcade monitor looks the same with both hacked and non-hacked boxes, again, this indicates that you did not hack the one to 15khz correctly.
If you followed the instructions here:
http://www.arcadecontrols.com/arcade_consoles.shtml#dc2arcade
You should have cut wire #6.  If you accidentally cut the wrong wire (like #7 if you counted from the wrong side) then just twist it back together, and cut #6.
abrannan
« Reply #4 on: August 30, 2004, 12:31:10 pm »
Interesting to note:  I have a VGA box that is missing one of the first six wires, so I had to cut #5 on the board (corresponds to #6 on the console cable).
unicron
  • Last login:September 26, 2005, 05:44:10 pm
    • My arcades
« Reply #5 on: September 22, 2004, 05:42:39 pm »
are you plugging your vga box into a jpac or are you wiring it directly to your jamma harness?
tenex2mg
« Reply #6 on: September 22, 2004, 05:55:23 pm »
ther is no JAMMA, there is no jpac...there is only a complete lack of soulcaliber on an otherwise kewl cabinet :).
Dave_K.
    • Arcade Fever
« Reply #7 on: September 22, 2004, 07:26:41 pm »
So I take it you are still not functioning?  Did you confirm that your hacked VGA box will NOT work on a computer monitor now (since it should be outputting 15khz which a computer monitor will not display)?
One last stupid question...you did try manually adjusting the vert/hoz gain on the monitor right??  You know that all 15khz inputs are not the same and do require monitor adjustment to get just right (normally just sizing the picture...but sometimes the sync could be off by .5 or more khz).
