Author Topic: Translucent Microswitch Buttons **www.fxbuttons.com**  (Read 109357 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
Re: Translucent Microswitch Button Thread **New Samples On The Way**
« Reply #320 on: May 15, 2005, 09:56:49 pm »
 :) They've assured me that once I order, production time will be about 3 weeks. So, yes, definitely this year...Optimistically, look for them by the end of June.
Oh man! Awesome! Does this mean we might actually get them by the end of 2005?!?!?
j/k...
I'm still in for a few when you get 'em...
I do hope it'll be in less then a few years though...
lol... Mean-lil' me...
shawnzilla
« Reply #321 on: May 15, 2005, 11:48:01 pm »
I finally got around to getting an led inside the button. Here are a couple of pics that I took:
1) The picture does not do it justice. My camera doesn't seem to want to take a proper picture in low-light conditions. Maybe I'll try setting up a tripod to eliminate the blurriness from the long exposure time.
2) It looks amazing with the light inside. A wonderful glow and not too harshly bright.
3) There is only one LED inside (a blue one from modsthatglow.com). I simply removed the plunger & spring, placed the led inside with the lead wires going out through the bottom. I put the plunger/spring back, hooked up the wiring and then put the microswitch back in.  This method worked great and did not interfere with the microswitch.
4) There was no need for "frosting" the plunger, as the led caused the whole thing to glow and it was not a glaring single point of light.
UndeadMeat
  • Last login:June 18, 2007, 09:59:48 pm
  • Life keeps getting in the way of my cab building.
Re: Translucent Microswitch Buttons **Updated Pics Of Lit Blue Button**
« Reply #322 on: May 16, 2005, 10:40:21 am »
I sure hope those new samples show up soon. I can't wait to see the other colors. If they come in at $3 a button you can put me down for around a dozen. Thanks for all your hard work in making this happen.
tetsujin
  • Last login:April 10, 2007, 05:51:25 pm
  • My controls will have programmable button labels.
    • My Homepage
« Reply #323 on: May 16, 2005, 01:09:04 pm »
I think frosting would be more useful for while the LED is off, so you don't look in there and see the button's innards too much...
But, really, if the button is unfrosted one can probably frost it at home.  That way people are happy whether they want it frosted or not.
---GEC
Chris
    • Chris's MAME Cabinet
« Reply #324 on: May 16, 2005, 01:56:57 pm »
--Chris
tetsujin
    • My Homepage
« Reply #325 on: May 16, 2005, 04:09:56 pm »
Might be tricky because of the small size, but spraying the inside of the plunger with a satin clearcoat should frost it quite nicely.
I was thinking a quick dip in acetone.  That way you'll get the outside of the plunger (meaning the full diameter of the button face will be frosted) and it'll be less likely to wear off than if you sprayed the outer surface of the button with clearcoat.  But whether that will work, I won't know until I get some.
---GEC
shawnzilla
« Reply #326 on: May 16, 2005, 06:30:49 pm »
Who can take a rainbow
Wrap it in a sigh?
Soak it in the sun
And make a strawberry pie
The buttonman
The buttonman can
The buttonman can
Cause he mixes it with love
And makes the world look good
...look for pics later tonight. If you liked the blue buttons, prepare to be stunned. The other colors (five colors total) will knock your socks off!!!
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Aww, damn it, gotta buy more socks....its bad enough when the dog eats them...
These are still at approx. $3 / button right?
pointdablame
« Reply #328 on: May 16, 2005, 06:58:52 pm »
Wrap it in a sigh?
Soak it in the sun
The buttonman
The buttonman can
The buttonman can
oh that's just cruel and unusual  :P
first off your and idiot
shawnzilla
I have no idea. Now that I have the samples, they're going to send me pricing. I don't think they wanted to confirm anything until I approved.
Chris
If Budda's coming LED interface could control tri-colored LEDs that could light up a button to be any color via software control, the clear ones are gonna be the sweetest thing on the planet...
--Chris
--Chris
Buddabing
--Chris
4-lead tricolor LEDs will work, but 2-lead tricolor LEDs will not.
Please read the wiki!
Chris
--Chris
Could you send three or four (or more) levels of voltage to the various colors, or would each one be on or off?
If controls.dat had the original color of each button... :)
--Chris
shawnzilla
PICTURES!
shawnzilla
MORE PICS!
shawnzilla
The pictures don't quite capture the vibrancy of these, but man, they are gorgeous!!!!
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
30 clear, please :)
UndeadMeat
WOW! Must have light up buttons! The red and clear ones look awesome! They are so cool that I can't stop using exclimation marks! Please oh please let them not cost like $10 each!
UndeadMeat!
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Just a photography tip for ya: Take pics of them again in the daytime.
NO MORE!!
Patent Doc
  • Last login:March 25, 2021, 12:07:33 pm
  • My wife says I'm the fastest man alive :(
Hey Shawn just for you in my best Alabama drawl...Them thangs sure look purty...make a grown man cry...I could shed a tear...sniff....sniff.
Looks great man!! I'm still in it for blue, green, and red, awe hell, why not all five.
These look fantastic.
Patent Doc
Buddabing
--Chris
The controller has 16 levels of voltage, plus off. An unmodified 40-LED controller would only be able to control 13 tricolor LEDs. Each tricolor LED would theoretically be capable of 4913 (17*17*17) different colors. The 13 LEDs is because the red, green, and blue ports on each LED would require one connection on the controller.
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
It's official, I'm going to buy some now....are you taking pre-orders yet or waiting for pricing?
Thanks,
southpaw
shawnzilla
Thanks,
southpaw
Waiting on pricing. Hope to know in the next day or so.  :)
Kingspinner
  • Last login:September 12, 2007, 08:37:52 pm
  • The King has Entered the FORUM!
These are amazing!!!  :'( :o ;DWith Happ illuminators at over $6 a pc, these HAVE to be less expensive. I would love 6 each of red and blue if they are under $4. Please!!  With Cherries!! I gotta have em! :o
whammoed
  • Last login:January 31, 2026, 10:01:01 pm
  • Crack don't smoke itself
    • NiceMite
They do look very nice, even better than the original pics. :o
The green however doesn't look translucent at all.  :-\ Is this the case or is it the picture?
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
Wow! I've gotta get a bunch of these! For what, I'm not entirly sure yet.
Some pictures of these mounted would be good. It would also be cool to see some pics of what the clear ones look like lit up with different color LEDs (including pure white).
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
NY_in_TX
  • Last login:February 25, 2017, 11:19:54 am
  • First play's free...next one will cost ya
man, looking good!
Yes more pics, especially of the green.  the others seem to look top notch.
2 questions
Is this going to be a complete button, with inner spring and microswitch?  I gotta have cherry switches for these badboys so I'd like it without the swithc  if the brand isn't cherry (could save you some $$).
and
why is that chick on the coach not freakin out about those totally awesome buttons?!
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
She's thinking about when he used to look at her that way.
Tiger-Heli
    • Tiger-Heli
Those buttons look awesome!!!
Kev-in DFW
  • Last login:September 10, 2008, 12:36:09 pm
  • Duke it out amongst yourselves...
The buttons are MUCH better than I would have thought they would turn out.  Hopefully, the price will be much better than anyone could have hoped as well.  I like the price you mentioned early on in the thread when you were getting all kinds of pressure to divulge one!
Let us know and then how long will it take for them to come in?
Thanks for the hard work!
Kev
The biggest tragedy in life is not death, but what dies inside of us while we are still alive...
cholin
    • Nilok Productions
Man, you gotta put an LED in them and take pics, these look amazing!!!!!!!!!!!!!!!!!
OUCH!
gl.tter
  • Last login:October 10, 2009, 04:53:44 pm
Nice Shawn.
author of the Quake2 and Half Life Act Labs lightgun conversions:
Chris
Now if we could get the clear ones with the one and two player start icons on them... :)
--Chris
shawnzilla
Nice Shawn.  I'm now tempted to cross over from translucent leafs to your clears and RGB LEDs!
I've edited one of the pictures a bit - I suspect that's closer to what they really look like:
Thanks Glitter! That does look much closer to what they really look like.
As far as the green ones go... They ARE translucent. They are dark green, almost the same as the translucent green leaf switch buttons (the colors were all modeled after the translucent leaf switch ones).
Production time will be 2 - 3 weeks from when I order them. Whether I order all five colors in the beginning will depend on 1) Pricing 2) Minimum order amount. As I've said in the past, I will keep the pricing as low as I possibly can. If needed, I will do a pre-order list and then make the order once I have enough (I'm hoping the pricing will be low enough that I won't have to do this).
The chick was not freaking out, because she was mad that I was working late and then came home and wanted to play with my buttons!  ;D Ah, the life of a realtor with a hobby....
The microswitches are Honeywell. I'll have to see if there's a price difference for cherries. But, one thing the manufacturer is adamant about is that I have to order these with the microswitch. They will not sell me the buttons alone.
Yes, these are the complete buttons w/ Plunger, Spring, Bezel, Nut and Microswitch.
One thing is certain, these buttons will look awesome both lit and unlit.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
I wasn't originally planning on clear buttons, but those look sexy.
Chris
I'm hard-pressed whether to go with all clear buttons and select their color via LED or use colored cuttons.  I'll bet a blue button witrh either a blue or white LED looks better than a clear button with a blue LED...
--Chris
gl.tter
RayB
  • There's my post
    • RayB.com
OK Shawn, what about durability? Have you done any "agressive" tests to see if they are just as durable as normal buttons? I remember reading that part of the issue here is the plastics are more brittle, which means they can crack and/or be more noisy. What's the verdict there?
NO MORE!!
shawnzilla
They feel a LOT like the normal Happ Microswitch buttons. These are not the brittle plastic that people are used to seeing (both with the translucent leaf switch and the centsible microswitch ones). The noise is also comparable to the Happ buttons that everyone is used to.
These are very high quality, and the blue samples that I installed in my cab have been doing really well.
tetsujin
    • My Homepage
The orangish ones...  do they really look orange in person or are they more yellow?  They look more on the orange side to me, so I like 'em!  Let's see the tops of those buttons!
---GEC
