Author Topic: -listxml ...and Mame32  (Read 5771 times)
JamieDeb
  • Last login:August 25, 2004, 07:03:22 pm
« on: August 25, 2004, 07:07:23 pm »
I try (without success ;-) to do a -listxml with Mame32 ?
Is it possible with that version...or only mame (not 32) version?
i'm using this syntax..is it correct (it doesn't work for me!):
c:\mame\mame.exe -listxml >c:\mame\list.xml
Thanks very much for your help !!
Re:-listxml ...and Mame32
« Reply #1 on: August 25, 2004, 07:08:41 pm »
Isn't it mame32.exe?
JamieDeb
« Reply #2 on: August 25, 2004, 07:11:50 pm »
yes, sorry:
c:\mame\mame32.exe -listxml >c:\mame\list.xml
Is it the correct syntax ?
« Reply #3 on: August 25, 2004, 07:13:23 pm »
Looks right to me, try a space between > and c ?  I'm not sure if mame32 can do those commandline switches?
JamieDeb
« Reply #4 on: August 25, 2004, 07:21:40 pm »
I've tried with "regular mame (not mame).
If you put a space it dooesn't work at all.
With that syntax (and "regular" mame", I can see a DOS windows appearing and the listing of all games running...but no files written to the disk.
Could you please help ? Thnaks
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #5 on: August 25, 2004, 07:24:52 pm »
yes, sorry:
It worked for me but assuming you dont have mame installed it should be:
c:\mame32\mame32.exe -listxml > c:\mame32\list.xml
« Reply #6 on: August 25, 2004, 07:41:17 pm »
Did you do it from a Command Prompt or from Start > Run?  Make sure you do the former...
SirPeale
  • Green Mountain Man
« Reply #7 on: August 26, 2004, 02:11:52 pm »
don't speficy the path when writing the .xml file.
C:\MAME32> mame32 -listxml > mame.xml
JamieDeb
« Reply #8 on: August 26, 2004, 02:49:33 pm »
You're right...it now works if I use a command prompt instead of the "Start > Run" system.
Thanks very much!!
