Author Topic: Joystick Leaf Contacts Question  (Read 1279 times)
KC
  • Last login:February 21, 2005, 12:39:07 pm
« on: August 25, 2004, 06:14:13 am »
Hi all,
I've been playing around with my controllers, trying to get the X-Arcade and Hotrod to work side by side. I haven't used either of them in a year or so. While playtesting I realised that quite frequently (at least once or twice per minute) it would get stuck to the left, right, top...any direction. To unstick, I have to hit that direction with the joystick again...not good when hectic 1942 evsaive action is needed!
Since it happened with all 4 sticks I thought I have a config or keyboard problem. After fiddling for an hour or so I hooked up my joystick kit, which is my newest and most used controller. This works perfectly.
So, I wonder, do the leaf switches of the controllers get old. Do contacts wear out? Do they have to be exchanged after having been idle for a long time? Remember, I hadn't used HotRod or X-Arcade in ages, and last time I did they worked perfectly...
Any ideas?
Cheers
KC
www.mameworld.net
You know it makes sense!
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Re:Joystick Leaf Contacts Question
« Reply #1 on: August 25, 2004, 09:49:10 am »
is this the famous issue of using 8 way joysticks to play mame games that originally had 4 way joysticks? its been discussed many times before here.
i'm putting a tstick plus in my cab just because of this - sop can switrch between 4/8 way mode depending on the game
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #2 on: August 25, 2004, 09:59:09 am »
i believe that the x-arcade and the hotrod both use microswitch joysticks, not leaf..
KC
« Reply #3 on: August 25, 2004, 10:18:16 am »
Duh, yes,of course, microswitch.
No it's not the 4way/8way issue, I have a dedicated 4 way for Pac-man and such.  I believe 1942 and other similar shooters all use 8 way. In any case, as I said, my joystick kit controller with 2 Happs works perfectly without a hitch, but the hotRod and X-Arcade all stick :(
Cheers
KC
www.mameworld.net
NoOne=NBA=
« Reply #4 on: August 25, 2004, 05:18:54 pm »
My guess is you're having some driver problems with the encoders on the HotRod and X-arcade.
Do these two controls work separately, and only have problems when used together?
Does your Happs control use a different encoder?
Does the Happs work when daisy-chained in with the HotRod or X-arcade?
It would be almost unheard of for ALL the switches to go at once like that.
If it were only one or two switches maybe, but not ALL of them.
KC
« Reply #5 on: August 26, 2004, 03:25:53 am »
Hmm, you might have a point. The one that works uses an Ultimarc encoder.
On the MAMEWorld board Orc suggested the only time he saw this was an X-Arcade plugged into a laptop. And indeed I use a laptop. Could that be the problem? I guess I'll need to try everything on my other PCs, too...
KC
*edi* It IS the laptop...the controllers work fine on my other PC. Lesson learnt: Ultimarc encoder works with laptop. HotRod and X-Arcade don't....
« Last Edit: August 26, 2004, 04:15:12 pm by KC »
