Author Topic: Drilling template for my coin door?  (Read 2045 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: August 24, 2004, 11:44:27 pm »
Does anyone know if there is a mounting/drilling template available for my newly purchased coin-door that should be arriving soon? It is an Atari Coin Door. Here's the pic:
Ken Layton
  • Guru
  • Technician
Re:Drilling template for my coin door?
« Reply #1 on: August 25, 2004, 12:50:21 am »
That's a COINCO model 2802 coin door.
shawnzilla
« Reply #2 on: August 25, 2004, 08:14:22 am »
Cool. Do you know where I can get any mounting info on this?
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #3 on: August 25, 2004, 08:41:14 am »
I purchased an over/under from Happs for my coin door. I just used the coin door itself for my "template".
Should be able to lay the door down, trace the outline, and finally mark a new line inside this one based on the space between the  outer edge and the amount you need for overlap.
I intentionally error'ed  on the  tight  side when I did mine and then sanded slightly  to make a nice  snug fit.
Measure twice,  cut once.
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #4 on: August 25, 2004, 09:23:57 am »
i also just fitted a happ over/under.
i waited until the door arrived and cut to that. didn't want to risk the dimensions of the diagram on Happ website being wrong.
worse thing to do is be impatient and cut the hole too big.
BTW: anyone have any spare mounting bolts?
the silver screw bolts i used just don't look right ;)
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
« Reply #5 on: August 25, 2004, 09:58:29 am »
You don't need a template just measure the inside edge of the door where the hole needs to be and draw the measurements on the front of your cab.
Next take a small paint can or food can and use it to draw the rounded corners of the door.
Place the door over the shape and make sure it's outside the lip of the covers the hole you are going to cut out.
Cut the hole out and fit the coin door if the corners are tight use a rotary tool  to sand them down a bit.
Thats it.
Gary
gregor7777
  • Last login:March 14, 2022, 04:07:00 pm
  • I'm your huckleberry. Say When...
« Reply #6 on: August 27, 2004, 10:28:52 am »
Ghoward has it.
Remember also that as long as it fits it doesn't even need to be perfectly precise as the front overlaps and covers the hole by quite a bit.
