Author Topic: Mame Arcade Conversion  (Read 3993 times)
Duane Cravy
« on: May 22, 2002, 08:19:37 am »
Would a Street Fighter II coinop with 6 buttons be a good choice for a mame Conversion with a j-pac?
Any suggestions would be helpful.
Guest
Re: Mame Arcade Conversion
« Reply #1 on: May 23, 2002, 05:24:54 pm »
I sure as hell hope so... that's what I'm planning on doing!  :D
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #2 on: May 24, 2002, 09:44:19 am »
A SFII cab would be a good candidate. That's probably a jamma cabinet, so you could use a jpac, and just plug the cabinet into your PC.
Bob
South Carolina
gnat3y3
« Reply #3 on: May 24, 2002, 09:09:48 pm »
its alrready got 2 joysticks 6 buttons each, perfect!
and most likely jamma! sweetness
goto town!
wes
« Reply #4 on: May 29, 2002, 12:56:42 am »
I am planning on doing the same thing and wanted some advice on using the existing monitor thats in the cabinet.  I should be able to purchase the Trident Blade T64 with the J-Pac and be able to run windows on it correct? I would like to use a CPS1 & CPS2 emulator on there and so far the only ones I can find are W32 based.
Any other recommendations for video cards that would run at the 15khz setting?
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #5 on: May 29, 2002, 10:33:22 am »
cpsmame and geomame are mac.
