Author Topic: Help with shuffleshot analog settings!  (Read 1051 times)
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« on: August 21, 2004, 01:44:17 pm »
Ok I just discovered shuffleshot, and its great!!  My problem is that every time I slide the puck I get "Hey slow down!" and it slides off the field.  I have a Happ 3" trackball connected directly to the Optipac.  What should I set my analog settings at?  Also, when i change the analog settings within this game, does it change it for all track games, or just this one??  thanks in advance!
ED
Re:Help with shuffleshot analog settings!
« Reply #1 on: August 21, 2004, 02:35:56 pm »
Not sure exactly...the analog settings will vary depending what hardware is used.  I have the same setup (Happ 3" & Optipac), but I seem to remember playing it the other week with the stock settings.  Either don't whack the trackball as hard or lower your analog sensitivity until it feels right.
Analog sensitivity is game-specific (atm at least), so you have to adjust games individually.
