Author Topic: A picture of a T-nut?  (Read 1591 times)
PixelCloud
  • Last login:April 26, 2005, 07:15:14 pm
« on: August 20, 2004, 06:26:31 pm »
does anyone have one? i would like to know what they loook like and how to install them
thanks
Witchboard
Re:A picture of a T-nut?
« Reply #1 on: August 20, 2004, 07:25:43 pm »
Mameotron
« Reply #2 on: August 21, 2004, 12:49:40 am »
Here is a picture and a table of some sizes they come in.
You'll notice that there are 2 numbers listed for size.  the first number (8-32) is the size bolt that will screw into it.  The second number (1/4) is the size hole you have to drill to stick the thing into.
The t-nut goes on the bottom of your wood, with the points facing up.  Your bolt goes down into it from the top.  So when you tighten the bolt, it pulls the points of the t-nut up into the wood.
« Last Edit: August 21, 2004, 12:50:01 am by Mameotron »
JAMMA Guy
  • Last login:June 18, 2004, 01:14:07 am
  • PCB's Are Better!
« Reply #3 on: August 22, 2004, 02:11:30 am »
 .... or in the case of the control panel ... they are recessed, pointed facing down, and the bolts go in from the underneath through the joystick into the t-nut pulling it down into the material ;D
#10-24 T-Nut this is what you'll be needing  ;) (along with a 10-24 (3/4") machine screw ... that's assuming your using 3/4" building material)
« Last Edit: August 22, 2004, 02:18:16 am by JAMMA Guy »
Robopede
  • Last login:October 18, 2004, 11:24:52 pm
  • 80's rule!
« Reply #4 on: August 22, 2004, 10:27:02 pm »
Do T-nuts work o.k. with hardwood, like oak? Or are they just for MDF and softer woods?
I just happen to be trying to figure out how to attach the joysticks to the CP too... I wanted to use elevator bolts, but they don't seem to be manufactured small enough. T-nuts look like a possible alternative.
Look inside and you will see
The dream is my reality
JAMMA Guy
  • PCB's Are Better!
« Reply #5 on: August 23, 2004, 08:34:48 am »
They work with hardwoods.
Hmmm ... if you're going for a natural wood look ... then I don't recommend them at all.
The installation of them would total ruin the overall look of your cabinet ... the control panel would look like crap.
If your laminating or painting ... then I say go for it.
As for installation into oak ... you'll probably need to pound them into your 3/4" recessed hole using a punch and hammer ... unlike MDF of Particle Board ... there not going to sink in easily just by tightening up the screw.
« Last Edit: August 23, 2004, 08:37:23 am by JAMMA Guy »
Robopede
  • 80's rule!
« Reply #6 on: August 24, 2004, 05:33:56 am »
Cool. I plan to cover the hardware with artwork.
WTFPWND
  • Last login:August 24, 2004, 11:31:45 am
« Reply #7 on: August 24, 2004, 11:33:16 am »
I used these to bottom mount everything on my CP.  Nothing has cracked or come loose yet.
« Last Edit: August 24, 2004, 11:33:38 am by WTFPWND »
