Author Topic: Cap Kits and schematics  (Read 1942 times)
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
« on: August 19, 2004, 02:02:25 pm »
Where could I get a cap kit and/or locate a schematic for the following B/W monitor?
TEC TDY-1005M
3021009
Thanks for any help, I check bobroberts website but it doesn't list this monitor...
Mike
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
Re:Cap Kits and schematics
« Reply #1 on: August 19, 2004, 03:44:05 pm »
Not a single result on Google when searching for "TDY-1005M".
Happy hunting :)
SirPeale
  • Green Mountain Man
« Reply #2 on: August 19, 2004, 04:25:00 pm »
Likely you'll have tp pull the board, note the cap values, and put together your own 'kit.'
MiKman
  • Blah
« Reply #3 on: August 19, 2004, 05:04:33 pm »
I see bob roberts has a kind of mixture of caps for $7.50  maybe I could just order that and kinda hope for the best...
Am I correct in saying that the model/type listed on the tube is not the monitor you need for the capkit? Cause I found the TEC TDY-1005M on a small yellow tag laying in the bottom of the cabinet.  Here are some shots of the monitor PCB, maybe someone might recognize it. (wishful thinking ;) )
MiKman
  • Blah
« Reply #4 on: August 19, 2004, 05:13:38 pm »
And is a short video showing the problem with the monitor kind of jumping around.  It progressively gets worse the longer the game is on until it eventuall just starts to break up entirely...  I played with all the various pots on the board except the one in the center of the PCB. I can't reach that one safely :-)
BTW ignore the noise in the background, it's just my dog having a drink of water :D
« Last Edit: August 19, 2004, 05:15:19 pm by MiKman »
MiKman
  • Blah
« Reply #5 on: August 19, 2004, 05:21:32 pm »
Just noticed this in the closeup of the pcb does this look melted to anyone else?  maybe this is part of the problem :)
Ken Layton
  • Guru
  • Technician
« Reply #6 on: August 19, 2004, 06:02:49 pm »
I know what you have. It's either a TEC model TM-600 (19") or TM-623 (22" or 23"). Manuals should be at mikesarcade.com
The last address I had for TEC was this from 20 years ago:
TEC Videoelectronics, Inc.
3010 Scott Blvd.
Santa Clara, Calif. 95050
(408) 246-5428
I'm sure the area code has changed over the years.
Check the foil side for bad solder joints.
WARNING: This chassis is well known for suddenly catching fire!  :o
Did I mention checking the solder joints?
I see that Bob Roberts has capkits for this chassis and I would strongly suggest getting that capkit pronto as some of the original caps actually catch fire. The replacement caps are much higher ratings so once you get those in you'll be ok.
« Last Edit: August 19, 2004, 06:15:31 pm by Ken Layton »
MiKman
  • Blah
« Reply #7 on: August 19, 2004, 09:02:01 pm »
wow excellent, thankd for the Help Ken.  I downloaded the pdf for the monitor you suggested from mikesarcade and the chassis looks exactly like mine. looks like we have a winner :-)
Ken Layton
  • Guru
  • Technician
« Reply #8 on: August 19, 2004, 11:49:24 pm »
Glad to help.  ;D
These monitors were not very popular at all. The only games I ever saw them on were Atari Starship 1 and Atari Super Bug.
MiKman
  • Blah
« Reply #9 on: August 20, 2004, 12:57:54 am »
and now on a desert patrol too.
