Author Topic: USB trackball and spinner in XP  (Read 914 times)
albrigsr
  • Last login:July 29, 2016, 09:24:49 am
« on: August 18, 2004, 08:42:18 pm »
I am using XP Professional.  I currently have a Happ Trackball & Oscar Spinner interfaced via a Hagstrom ME4.  The spinner works correctly,however, the trackball only works only on 1 axis.  I haven't been able to troubleshoot it much but am thinking of moving to a USB Happ trackball and leaving the working spinner on the ME4.  Will both work correctly in XP Pro?  Can the Trackball control the mouse in the windows environment even though the spinner will be connected via the ME4 to the PS/2 Mouseport?
I appreciate your help!
OSCAR
    • Oscar Controls
Re:USB trackball and spinner in XP
« Reply #1 on: August 18, 2004, 08:56:03 pm »
Here is a quick test you can do to help isolate the problem:
Switch the x- and y-axis connections from the trackball to the ME4.  If the same axis is not responding, then your problem is with the ME4.  If the problem moves to the other axis, then your trackball is the culprit.
I had a brand new Happ trackball that didn't work on one axis when I received it.  After checking the continuity of the trackball wire harness, I found that one of the signal wires was broke inside the colored wire coating.  I cut the wire and spliced it back together where the break was, and it worked fine after that.
Any "mouse" (desktop, spinner, trackball, etc) connected to your PC in Windows, regardless if it is PS/2, USB, serial, will act as the system mouse and allow you to navigate within Windows.
