Author Topic: Leaf switch button question  (Read 4534 times)
anoon
  • Last login:November 03, 2022, 09:24:53 pm
« on: August 26, 2002, 03:01:37 pm »
I am not familiar with the leaf switch buttons. Can somebody tell me how they fasten to the control panel? I see that Wico sells something called a pal nut that costs nearly $10!!! Is this what is used to tighten the button down?
Lilwolf
Re:Leaf switch button question
« Reply #1 on: August 26, 2002, 03:11:38 pm »
I bought 50 from ebay for a few bucks (50cents each I think)
going from memory here.... haven't installed one in a while...
I have 2 types... and don't know the brand or anything.
But basically the button goes throught the control panel (by itself) and has a screw on the end... that you screw into a plastic piece that holds the leaf switch.
So the button itself is a self contained plastic tube (with the button on top)... that when pressed, pushes a throught the whole button shaft thinggy.
Then this screws into the base...which holds the leaf switch itself.  So when the button presses, it will then press on the leaf...
btw, I have them on my classic control panel (4way... then asteroid button setup... then 4way turned for qbert).  But thats about it.
They are great for hacking other controllers though..
anoon
« Reply #2 on: August 26, 2002, 03:35:08 pm »
Ah ha. I get it. Thanks for the info.
I'm looking to build a cabinet with illuminated pushbuttons.
One option was the transparent leaf switch buttons, (about $3.75 with switch, holder and button.) Downside is limited color choices, leaf switch reliability, and I'm afraid I don't have enough room under the Control panel.
The other were these illuminated microswitch buttons from Japan. (about $10 a piece.) The downside is mainly the price.
Now I suppose it just depends on which feel I prefer...
Grasshopper
« Reply #3 on: August 26, 2002, 03:37:48 pm »
There is no way you should pay $10 for a pal nut. I think Wico must have made a mistake, perhaps they meant to say $0.10.
By far the best place to get leaf switch buttons is www.videoconnect.com. I bough some from them and they cost $0.50 each including the leaf switch, leaf switch holder, and pal nut.
The problem with leaf switch buttons is that they are only designed to fit panels of a particular thickness. The long ones are designed for 3/4" wood, and the short ones are designed for metal. There are various hacks for fitting them to other thickness materials but it gets a bit messy.
However there is really no alternative if you want maximum authenticity for the early games (as I do!).
anoon
« Reply #4 on: August 26, 2002, 03:57:34 pm »
Good point about the panel thickness Grasshopper. I forgot to mention that earlier.
I really want to go with a blue and white scheme for my panel, which severly limits my options. I have a wood panel, so the only colors I can get are blue, orange, and green. I did find some white buttons, ($4, just for the button, no switch or holder,) but they are the short type.
Actually, I was planning to put a metal surface OVER the wood, so maybe I could just cut out a large rectangle of wood under the metal where the buttons go. Its starting to sound like a hassle. I think i would rather spend the extra $$$ and just get the japanese buttons. I have always been drawn to their unique feel. (I like it, I'm not sure if I prefer it or not.)
This newfound hobby is a blast!
anoon
« Reply #5 on: August 26, 2002, 04:03:22 pm »
Almost forgot:
Does anyone have experience ordering from Sanwa in Japan?
