Author Topic: Wow, this is starting out badly...  (Read 2492 times)
Howtobefreaky
  • Last login:August 13, 2004, 03:18:23 am
« on: August 14, 2004, 01:42:26 am »
Hi, I've decided to start building my own MAME cabinet, and I'm playing around with different front-ends and I've heard great things about MameWAH. So I download it and follow the directions by settings mame as emulator 1 and I set the games list. I follow the first 3 steps in the readme and I refresh the games list. Nothing. Not a single game is showing. The games list is Main and the emulator is set to MAME. I know that all the folders I put in are correct, but I don't get anything. I can also play the games through regular command prompt and mame. I've tried to find the answer but I just haven't found it.
Howtobefreaky
Re:Wow, this is starting out badly...
« Reply #1 on: August 14, 2004, 01:53:37 am »
Okay, I got the list of games by doing Rom Folder Only even though it's not what I want in the long run.
But now when I hit "1" to play the game, it brings up a box saying:
Loading:
Mslug2 (for example)
And then the box goes away and it acts like I never did that.
Howtobefreaky
« Reply #2 on: August 14, 2004, 02:33:12 am »
Oh, and if someone could please explain to me what a DAT file does, and how I can make one, that'd be much appreciated.
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
« Reply #3 on: August 14, 2004, 10:14:12 am »
i also have got same problem.....
but u can be one step forward to make a DAT file......
this file contains all the information of the mame.exe
supporting games,rom information etc.
u can make ur own dat file in simple steps.....
1)go to the dos promt .
2)c:/dmame -xml2info >dmame.dat
.......ok......
BLUE BIRDS FLY WITH BLUE BIRDS
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
« Reply #4 on: August 14, 2004, 10:24:00 am »
Can you paste up your EMU1 CFG File from Mamewah / Files / EMU1 .. maybe theres something in there we can pick out? I say this as I had exactly the same problem .. and I can't for the life of me remember what it was, but I'd like to try and help :)
I'm sure it was just a setting that was out ... nothing too complicated.
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
Howtobefreaky
« Reply #5 on: August 14, 2004, 12:22:39 pm »
.......ok......
Tried that and when I tried /dmame it said that it was not recognized as an internal or external, operable program or batch file.
And when I tried it with just mame (no 'd's' in front) it said "Error: Unkown option -xml2info
Error while parsing cmdline"
Okay...I don't exactly get what you mean by this. Do you want me to just post what the names of the CFG files there are in that folder, or is there a way I open them up and post what's inside of them by notepad or something? I'm good at overcomplicating things :)
And just so you know, mame.exe is in my C:\ folder (so it's C:\Mame.exe) and my roms are in C:\roms.
Halo
  • I'm a lamer!
« Reply #6 on: August 14, 2004, 12:26:09 pm »
No problem .. believe me, I've only just discovered this myself with the help of the good people here!
If you go into your Mamewah folder, then click 'Files', then open up the 1st 'cfg' file .. I think it's called 'EMU1' (I'm on a different PC) .. then just open it up with Notepad and paste about the top half. It just might be something someone can see easily.
Howtobefreaky
« Reply #7 on: August 14, 2004, 12:39:41 pm »
Okay thanks, that helped a lot. I'll put what it says in quotes so it's easier to read:
;MAMEWAH v0.97 EMULATOR 1 CONFIG
;LIST GENERATION SETTINGS
ROM Path = C:\ROMS
ROM Extension = ZIP
List Generation Method = 3
;EXECUTION SETTINGS
Emulator Executable = C:\MAME.EXE
Send ROM Path = False
Send ROM Extension = False
Use Long Filenames = False
Use Quotes around ROM Filenames = False
Show DOS Box = 2
Default Options =
Extra Options #1 =
Extra Options #2 =
Controls.dat Viewer Filename =
Controls.dat Viewer Default Options =
Launch Controls.dat Viewer before Game = True
IPC Filename / Path =
;MISC SETTINGS
Emulator Title = MAME
Artwork #1 Image Path = C:\SNAP
Artwork #2 Image Path =
Artwork #3 Image Path =
Artwork #4 Image Path =
Artwork #5 Image Path =
Artwork #6 Image Path =
Artwork #7 Image Path =
Artwork #8 Image Path =
Artwork #9 Image Path =
Artwork #10 Image Path =
Artwork #1 Filename to Replace =
Display Clone Info (in Custom Lists) = False
;SCREEN-SAVER SETTINGS
Type = 1
Wrapper Executable =
Wrapper Default Options =
walls83
  • beer is good
« Reply #8 on: August 14, 2004, 01:58:45 pm »
Have you downloaded MAMEWAH SETUP?  If not get it.
http://www.mamewah-setup.co.uk/html/info_settings.html
Then go here for walkthrus on setting up almost all systems.
SirPeale
  • Green Mountain Man
« Reply #9 on: August 14, 2004, 02:02:47 pm »
I'm guessing you're trying to use the latest version of Mame?
MameWAH doesn't *exactly* support it  That's coming in the next release.  To get the game names to show up, create a dat file with this command (using the Mame exe and xml2info)
mame -listxml | xml2info > mame.dat
that will create a dat file that MameWAH can read.
Howtobefreaky
« Reply #10 on: August 14, 2004, 02:31:08 pm »
Alright, I created a .dat file and I downloaded that setup program. Using that program, I succesfully got all the games to show up and their titles. Exactly what I wanted. They still don't play though. Is it supposed to not play since I'm using the latest version of Mame? If so, I'm happy because I'm finally where I'm supposed to be. Guess I'll just wait for the next version of MameWAH...
« Reply #11 on: August 14, 2004, 02:32:48 pm »
If it won't play then it sounds like your Emulator Executable or something else is not setup correctly...
Howtobefreaky
« Reply #12 on: August 14, 2004, 03:11:24 pm »
OH MY GOD. I am about to cry. I finally got it working. I just put everything in a main folder (C:\Mame) and then put the roms folder in there. Then I completely uninstalled MameWAH (like deleting the folder it was in) and installed it again. It works! Now I just need to figure out how to get Metal Slug 1 to work correctly, but that shouldn't be too hard.
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #13 on: August 14, 2004, 03:46:36 pm »
Metal Slug needs the Neo Geo bios rom, neogeo.zip.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
Howtobefreaky
« Reply #14 on: August 14, 2004, 04:03:31 pm »
Yea, I had those. I figured it out. The rom was just corrupted.
Howtobefreaky
« Reply #15 on: August 14, 2004, 04:36:27 pm »
Alright, I have another problem (let's just consider this Howtobefreaky's help topic, shall we?).
Since I moved everything (including MAME.exe and all it's components) I can't make a dat files anymore. I tried Peale's command that worked the first time, but this time it said:
error: Unknown option -listinfo
error while parsing cmdline
1::no element found
I have no idea what this means, but maybe you can make some sense out of it.
« Reply #16 on: August 14, 2004, 04:42:01 pm »
1::no element found
Go up & read Peale's commandline again...no 'listinfo' in sight ;)
Howtobefreaky
« Reply #17 on: August 14, 2004, 04:45:26 pm »
Sorry, I typed it wrong when I was writing this message. I was typing exactly how he said (xml instead of info) and it said the same thing only it replaced -listinfo with -listxml
« Reply #18 on: August 14, 2004, 05:24:00 pm »
Make sure you have the correct mame executable, and you typed it right (copy + paste it from here to make sure).
Howtobefreaky
« Reply #19 on: August 14, 2004, 06:07:37 pm »
Alright, I finally am able to make dat files. MSlug is acting up again but I should be able to fix it.
