Author Topic: How do I configure MamWah for an arcade monitor?  (Read 1459 times)
exibar
  • Last login:January 02, 2025, 11:38:59 pm
  • I'm the creator of Exibar's Lair!
« on: August 14, 2004, 01:20:43 am »
I don't want to blow my 25" WG arcade monitor with the wrong resolution.  So I figured I'd keep a separate power switch for the Monitor, and have MameWah play a sound once it loads.
  My question is this, how do I acomplish this feat?  Can MameWah adjust resolutions to be used on an arcade monitor?  I have an ATI 7000 Video card (actually it might be a 7500 now that I think of it).
   I'd like to use other emulators in my cab, so I don't think arcade OS will work for me.  Will it work with other emus too?
  thanks all!
  Mike B
Re:How do I configure MamWah for an arcade monitor?
« Reply #1 on: August 14, 2004, 02:08:51 pm »
I just answered this by email...for the benefit of the board:
You must be able to display Windows on your arcade monitor to run MAMEWAH...so if you can't do this you can't run MAMEWAH at 15khz...
scottyarc2
  • Last login:November 10, 2005, 05:33:53 pm
« Reply #2 on: August 15, 2004, 07:04:43 am »
Is it possible to setup mamewah to run at 15Hz if so how?? as i use mamewah in a cab via Arcage VGA and the quality is a little fuzzy ??
« Reply #3 on: August 15, 2004, 11:15:45 am »
Yes, if you can run Windows at 15khz...
If the display is fuzzy it sounds like you are probably running at 640x480 (interlaced).  Simply use a layout which is set for low-res (there is 'Classic 368x240' in the Layouts download at my site).  I run this res. and it looks sweet :)
