Author Topic: Best computer configuration for 3D games (teh noob question)  (Read 2859 times)
Laurent
  • Last login:August 15, 2004, 12:01:38 am
  • Si j'avais des dents, j'te les vendrais...
    • Nouvel Empire!
« on: August 13, 2004, 09:49:03 am »
My very first message on this board. So far, so good...
I am planning on building an MAME cabinet mainly to enjoy old time favorites (I've spend so much money on Street Fighter, Mortal Kombat and Killer Instinct arcades in the past, it's payback time) but I would also like to run more recent 3D games. I've looked everywhere for comparasion chart for MAME (or Nebula Sega Model 2 and Zinc emulators) with different PC configuration, without success.
I know that any card that supports Direct X 9.0 will work in Windows XP, but at what framerate? MAME is well-documented, except on it's 3D emulation. They said that a 3D card isn't necessarry, but what about Dead or Alive ++ or Tekken?
I will probably buy a AMD Athlon XP 3200 on a Nvidia nforce2 motherboard, but I have no idea about video cards... Can you help?
EDIT: Bold sections aren't covert on the FAQ threads of this forum...
« Last Edit: August 13, 2004, 10:10:38 am by Laurent »
lokki
  • Last login:May 05, 2025, 06:18:51 pm
Re:Best computer configuration for 3D games (teh noob question)
« Reply #1 on: August 13, 2004, 10:15:23 am »
MK and most of the street fighter series will run fine on a 1.6 Ghz system
MAME does not take advantage of video card hardware since the rendering is done on sotware by the CPU.  PSX system (tekken series, DOA, SF EX, etc) are not fully emulated in MAME (sound, and graphics aren't 100%) and these don't run full speed on any existing CPUs.
You could try Zinc for these games
Laurent
    • Nouvel Empire!
« Reply #2 on: August 13, 2004, 10:20:10 am »
That's why I've specified that I'll be using Nebula Sega Model 2 and Zinc emulation. I won't limit myself to MAME emulation, and that's why I need more answers on alternatives since those emulators are poorly documented.
« Last Edit: August 13, 2004, 10:48:04 am by Laurent »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #3 on: August 13, 2004, 11:55:05 am »
The emus will run on pretty much anything semi modern.  Zinc has glide support!  So you know we are talking a couple years old.
pointdablame
« Reply #4 on: August 13, 2004, 03:17:15 pm »
If you're running a 3200+ you'll have no CPU problems running Zinc or other non-MAME emus.  As for the video card, I'm not sure if those emus are "more" video card intensive than MAME, but I'm pretty certain they aren't very video card intensive in general.  If this is strictly a MAME/Emu machine, you'd probably be fine with a Radeon 9000/9200 chipset board.  Or you could get a 9500 if you perhaps plan on playing some PC games as well?  Anything more would be overkill.... even the 9500 is probably overkill IMO
first off your and idiot
Laurent
    • Nouvel Empire!
« Reply #5 on: August 13, 2004, 03:42:27 pm »
A friend of mine has offered me his ATI Radeon 8500; I might start with this one if no emulators requires specific 3D cards...
SirPoonga
  • Puck'em Up
« Reply #6 on: August 13, 2004, 04:45:18 pm »
there are older emulators liek ultrahle that require a 3dfx card, but you can get some newer emu for those usually.
