Author Topic: With bezel and smoked glass on TV, how do you use the remote?  (Read 944 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: August 13, 2004, 08:27:15 am »
Let me first say that I'm using a Toshiba 27A33 TV.  It works perfectly and I don't think I'll need a remote for a while, but what if I do need to use?
The *only* reason I might need it is for changing the input (if I put a DC or PS2 in my cabinet), or if I want to change the brightness/sharpness on the TV itself.
The problem is that when I put the bezel and smoked glass over the TV, there is no way for the remote to work unless I cut a small hole in the bezel.
Do most people cut small holes for this reason?  What do you suggest I do?
