Author Topic: Can I convert a slide switch to a toggle?  (Read 1105 times)
Fuzzguitar
  • Last login:November 26, 2012, 12:15:34 am
« on: August 12, 2004, 10:00:47 am »
Recently bought this;
http://www.flexiglowhk.com/website_files/products/Lazer.htm
but would like to know if I can convert it's slide switch (which sounds a lot like a "3 Position 3 Pole" Jaycar sell) to a toggle style switch.
I'm interested because toggles mount through a round hole and would be much easier to do on my metal panel. Would I need to get a "3 Pole Double Throw" (on-none-on) to do it? I'm a novice at electronics really but this seems possible to me as the slide is set up like this too: on-off-flashing (on-none-on)
Oh, forgot to say - click on Retail Packing to see exactly how I bought it. It cost $24.95 from Dick Smith Electronics.
« Last Edit: August 12, 2004, 10:05:53 am by Fuzzguitar »
"My cab is nearly finished, no really I swear!"
Tiger-Heli
    • Tiger-Heli
Re:Can I convert a slide switch to a toggle?
« Reply #1 on: August 12, 2004, 10:29:13 am »
I'm pretty sure you can.  I don't see any reason it wouldn't work, but I'm not an electronics expert, either.
ericball
  • Last login:March 13, 2025, 11:01:47 am
« Reply #2 on: August 12, 2004, 12:45:09 pm »
First figure out what is connected to the switch - AC, 5V DC, 48V DC?  Switches have voltage & current ratings.  Replacing it with something higher is typically okay assuming you're not dealing with micro-voltages & currents where switch resistance is critical.
Next, you need to determine the number of poles (the number of conductors which are switched).  So a double-pole switch can control two conduction paths (e.g. a stereo A-B switch, which has left and right conduction paths).
Finally, you need to know what the switch does with those conduction paths.  The basic ones are (but there are many others):
momentary contact is like a button, it is only on as long as you hold it
single throw is like a normal light switch, on - off
double throw is like an A-B switch, on - on
Then take that info and start looking for an equivalent toggle switch which meets your needs (and is panel mount  and the size you want).
MAME Projects % completed:
2004 3 sided cocktail cabinet w/ modular CP <25% (discarded)
2004 Tempest cabinet & CP > 75% (sold)
2017 Raspberry Pi Zero W w/ Lakka microconsole 50%
2021 Vertical Bartop - in progress > 80%, 100% functional (sleeping)
