Author Topic: did I mess up my ps2??  (Read 1860 times)
derek1800
  • Last login:January 29, 2005, 03:23:31 pm
« on: August 11, 2004, 05:43:53 pm »
I open my ps2 to start to install a power button for my cabinet and after I open it I cant even turn it on anymore. Anyone have any ideas of why this would happen?
Derek
hooded_paladin
  • Last login:November 06, 2013, 08:59:01 pm
  • Finch! hahaha
Re:did I mess up my ps2??
« Reply #1 on: August 11, 2004, 05:59:21 pm »
Maybe you tore the cable that connects the reset/eject button assembly.  Check that, or maybe head to richspsxparts.com for a helpful PS2 repair forum.
There is SO a spoon.
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #2 on: August 11, 2004, 06:04:56 pm »
most likely its a problem with that ribbon cable.  it could be torn as mentioned, but more likely just loose or disconnected.  make sure the cable is securely attached to both the motherboard and the button assembly.
make sure the red LED on the reset button glows when you turn on the power switch in the back.
derek1800
« Reply #3 on: August 11, 2004, 07:01:07 pm »
I dont even get the led to turn on so it must be a cable problem.
Thanks for the site
Derek
derek1800
« Reply #4 on: August 11, 2004, 08:04:09 pm »
checked all cables  :(
« Last Edit: August 11, 2004, 08:45:38 pm by derek1800 »
