Author Topic: Can I use a Standard TV?  (Read 1275 times)
PinoyArcade
  • Last login:June 09, 2004, 11:21:28 am
« on: August 10, 2004, 02:43:34 am »
I know this has been a topic already on the Monitor section....but is there a best way to use a normal TV instead of an arcade monitor for a cab ( pc board using jamma)
thanks
IG-88
Re:Can I use a Standard TV?
« Reply #1 on: August 10, 2004, 12:19:25 pm »
You might want to do some more digging around in this forum. This topic has been covered quite throughly.  ;)
-HarumaN
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #2 on: August 10, 2004, 12:37:37 pm »
if you are in europe go for a TV with RGB SCART input and get an ArcadeVGA graphics card from www.ultimarc.com this will give you an arcade perfect display ( for standard resolution games)
also check out oscars site http://www.oscarcontrols.com/ for arcadevga screenshots.
« Last Edit: August 10, 2004, 12:39:02 pm by rchadd »
StephenH
« Reply #3 on: August 11, 2004, 01:11:10 pm »
Yes you can use a standard TV.   However, unless you are in Europe and have one with SCART in, the picture quality will be lower than a monitor.
If you cannot get a SCART TV, I would highly recommend one with component or S-Video, and a TV out video card that can output Component or S-Video.   Using composite or RF will result in very low picture quality.
