Author Topic: Running MameWah without installing?  (Read 1474 times)
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« on: August 07, 2004, 07:35:41 pm »
Is there a way to run MameWah without having to install it onto the computer? I am going to be running my CP off a friends computer every now and then and I want to be able to just copy the disks contents into a temporary directory and then delete it when I'm finished. If I'm not mistaken MameWah writes to the system registry, meaning that if I just copy the MameWah directory's files onto a disk it won't work when I load it onto a computer that doesn't have it installed. Is there a way around this?
One other thing (instead of starting another thread), I seem to recall an NES emulator that already had the buttons set to the default MAME. With the one I use right now when I press Alt it brings down its menu. I also need a SNES one.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
pointdablame
Re:Running MameWah without installing?
« Reply #1 on: August 08, 2004, 01:50:18 am »
check http://www.screenshotarchive.com for emulators that use MAME keys.
I'm not sure about the Mamewah installation though, sorry.
first off your and idiot
« Reply #2 on: August 08, 2004, 10:54:15 am »
Actually MAMEWAH doesn't write to the registry (personally I don't like using the registry).
You don't need to install MW...you can use WinZip or similar to open the mamewah.cab file, and extract mamewah.exe to whereever you want.  You'll also need to extract paintx.dll to your \windows\system32 folder, and register it:
Start > Run > regsvr32 paintx.dll
Tahnok
    • Table Arcades
« Reply #3 on: August 09, 2004, 03:41:20 pm »
Oh, OK then. I copied the following files and will burn them to disk:
FILES
LAYOUTS
DEBUG.LOG
MAMEWAH Layout Designer.exe
MAMEWAH.exe
ST6UNST.LOG
paintx.dll
Will MameWah run off of the above when I put it on another computer?
pointdablame, thanks, that was the page I was looking for.
« Reply #4 on: August 10, 2004, 11:56:03 am »
Don't bother with the .log files, but yes that should work.
Remember what I said about paintx.dll tho...
