Author Topic: GensFE in Mamewah  (Read 1905 times)
Halo
  • Last login:April 26, 2005, 03:00:03 am
  • I'm a lamer!
GensFE in Mamewah
« on: August 07, 2004, 04:41:06 am »
I'm struggling to get GensFE to be recognised in Mamewah. I have followed the screenshotarchives suggested CFG settings, but when I select Emulator 2 in the list, nothing happens. I have it pointing to the GensFE.exe file. I can get GensFE to play by simply double clicking the .exe file, but not from within Mamewah.
Also, there are a number of different suffixes for the games, depending on which version (US, World, etc) .. is this okay, or should I be changing them to one common ending?
Thx
TJ
A stone falls on the pot, woe to the pot. A pot falls on the stone, woe to the pot. In both cases it is bad for the pot.
Re:GensFE in Mamewah
« Reply #1 on: August 07, 2004, 08:46:59 am »
So you have a list of games?
Is it when you hit start to play a game nothing happens?  If so check your Emulator Executable, and ROM Folder settings etc.  Also, make sure Show DOS Box is set to Yes (1 in the CFG file).
The suffixes are fine as they are :)
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #2 on: August 07, 2004, 09:10:22 am »
  Are you sure you increased the maximum number of emulators to show in MAMEWAH? It's a config setting...
-Steve
Halo
  • I'm a lamer!
« Reply #3 on: August 07, 2004, 10:03:22 am »
Thanks for the help! :)
No .. no games list, I go to the 'select emulator' part, and 1 is Mame (working fine). I flip down to 'Emulator 2' (haven't named it yet) ... press 1 and I just get the plain Mamewah screen (the one you get by default even before you add Mame).
However, when I simply double click the .exe for GensFE it's fine. I checked the path too in Mamewah.
The show dos box .. I don't think I did that part .. I'll go and check. Also, I didn't increase the max emulators setting .. shouldn't there be the ones showing by default?
Thanks again!
Tony
Halo
  • I'm a lamer!
« Reply #4 on: August 07, 2004, 12:06:38 pm »
Okay still no joy. I've pasted the top part of the CFG file, are there any obvious omissions?
ROM Path = C:\Genesis\Roms
ROM Extension = ZIP
List Generation Method = 0
;EXECUTION SETTINGS
Emulator Executable = C:\Genesis\GensFE.exe
Send ROM Path = True
Send ROM Extension = True
Use Long Filenames = False
Use Quotes around ROM Filenames = False
Show DOS Box = 1
Default Options =
Extra Options #1 =
Extra Options #2 =
Controls.dat Viewer Filename =
Controls.dat Viewer Default Options =
Launch Controls.dat Viewer before Game = True
IPC Filename / Path =
;MISC SETTINGS
Emulator Title = Emulator 2
Artwork #1 Image Path = C:\Genesis\Screenshots\Sega Genesis\screens
Artwork #2 Image Path = C:\Genesis\boxart\sega genesis
Artwork #3 Image Path = C:\Genesis\cartscans\sega genesis
Artwork #4 Image Path =
Artwork #5 Image Path =
Artwork #6 Image Path =
Artwork #7 Image Path =
Artwork #8 Image Path =
Artwork #9 Image Path =
Artwork #10 Image Path =
Artwork #1 Filename to Replace =
Display Clone Info (in Custom Lists) = False
;SCREEN-SAVER SETTINGS
Type = 1
Wrapper Executable =
Wrapper Default Options =
;CUSTOM LIST SETTINGS
List Selected = 0
No. Custom Lists to Display = 20
Cycle Main List = True
List 0 Name = Main List
Just a few more questions ...
What do the 'wah' bits stand for in Minwah and Mamewah? Also, where do we make a donation? Seeing someone so active in supporting their product on the forums has to be worth a few quid of anyones money.
« Reply #5 on: August 07, 2004, 12:43:11 pm »
Shouldn't make any difference but set this to False (unless you do have a CP viewer for Genesis).  The rest of your config looks fine, I think all you need to do is refresh the list (Games List Options > Refresh Games List).  Or maybe you selected a custom list with no games in it...try selecting the 'Main List'.
Dunno really!  For some reason Minwah is what my mates call me (I have a Mini)...MAMEWAH was a temporary title which stuck as I couldn't be bothered to think of something else :)
If you have a PayPal account, you can PayPal to my normal email address, should you feel the need :)
Soulcon
  • Last login:November 15, 2004, 07:15:08 am
  • Goober
« Reply #6 on: August 07, 2004, 01:01:56 pm »
Aye! Halo I was having the dangdest old time with those custom lists while using the keyboard. I would go to hit 6 to flip emulators and accdentially hit 5. Then it was a cluster fart trying to get back because I started flipping this that and going back and forward.  Just make sure in the upper right hand corner it says your emulator = Gens and the upper left says Main List.
Also May I suggest this it happened when I was trying to get Atari 2600 working. I believe you unzip Sega files so change the ROM extensions to the end file extension of your roms.   (.gen) or something like that. That should get you working.
-Soul
For a free XBOX, PS2, or Gamecube click Below http://consoles.prizecube.com/?ref=6788
To get a free Personal Video Player go here! http://www.pvps4free.com/default.aspx?r=1848
Halo
  • I'm a lamer!
« Reply #7 on: August 07, 2004, 01:06:02 pm »
Ahh ... the mystery demystified :)
Okay  .. I tried refreshing the games list and I got a 'runtime error' and when I press return, it exits to windows and Mamewah disappears.
Halo
  • I'm a lamer!
« Reply #8 on: August 07, 2004, 01:08:38 pm »
Thanks Soul .. will try that too! :)
Soulcon
  • Goober
« Reply #9 on: August 07, 2004, 01:58:16 pm »
Should look like this
ROM Extension = gen
And make sure they are unzipped :) also you will not need the . before the file extension either :)
-Soul
Halo
  • I'm a lamer!
« Reply #10 on: August 07, 2004, 02:58:26 pm »
Thats great, thanks a lot! I changed them all to their native .bin and they're up and rolling fine. Onto VirtuaNES now .. I have the lists showing, and the 'game loading' box appears, then it just sits on the screen like that until I hit escape .. I think the screenshotarchive might have a suggested cfg file though, so I'm off to look.
I just can't wait for Daphne .. hahaha. ;)
Thanks again guys .. awesome.
Soulcon
  • Goober
« Reply #11 on: August 07, 2004, 03:14:02 pm »
Make sure that you have the Virtuanes from
www.screenshotarchive.com/download_emus.htm
The Virtuanes is the best and works great but also don't forget the settings listed per emulator here is where I got all mine.
http://www.screenshotarchive.com/mwhelp.htm
They even have examples of what your config should look like.
Good luck they even have one for daphine ;)
-Soul
Halo
  • I'm a lamer!
« Reply #12 on: August 07, 2004, 04:11:51 pm »
Woo ... they have a different one called "FCE Ultra" ...  that has a config file too. I might check that one out if I can't figure the VirtuaNES out.
