Author Topic: Mamewah: can it rotate only some games?  (Read 1581 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: August 02, 2004, 11:08:43 pm »
Can I set up MameWah to rotate only certain DOS Mame games 90 degrees right or left?
I'm using a computer monitor and for now I don't mind reaching in and flipping the 15-incher around for vertical games.
Edit: after rtfm, I see the "-norotate" command-line parameter.  I guess that would work.  I was hoping to be able to go in manually and only flip *certain* games.  Is that possible?
« Last Edit: August 02, 2004, 11:38:48 pm by Dougmeister »
Re:Mamewah: can it rotate only some games?
« Reply #1 on: August 03, 2004, 06:44:24 am »
With WinMAME you can just use game-specific ini files...I don't think DOS MAME supports ini files tho (maybe in newish releases).
Long story short you can't do it using MAMEWAH :(
